Thanks Thanks:  9
Likes Likes:  59
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 103
Thread: Restoration/upgrades of FFR3490, MK2 built in 2002.
    Jan 2022
    Seven Hills, OH
    New video posted. Fixed leaking speedo cable, found that the trans fill plug is stripped and came up with a work-around, changed trans fluid, cleaned and installed rear wheels, and continued wiring cleanup on the right front corner. Enjoy!
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  2. Likes jrcuz liked this post
  3. #42
    Jan 2022
    Seven Hills, OH
    New video posted. The beast is back on the road. Finished up the front end wiring clean up, replaced missing trans bolt, set ride height in front, cleaned and installed wheels, and went for test drives after setting tire pressures at 23 psi. Enjoy!
  4. Likes jrcuz liked this post
  5. #43
    Jan 2022
    Seven Hills, OH
    New video posted. Found some issues on test drives and installed front and rear Cobra badges. Enjoy!
  6. Likes jrcuz liked this post
  7. #44
    Jan 2022
    Seven Hills, OH
    New video posted. First attempt at correcting the ride height and sealed the leaking rear diff girdle studs. Enjoy!
  8. Likes jrcuz liked this post
  9. #45
    Jan 2022
    Seven Hills, OH
    New video posted. Fixed the prior owners’ fubared hack-job timing and added insulation. Car drives SO much better. Enjoy!
  10. Likes jrcuz liked this post
  11. #46
    Jan 2022
    Seven Hills, OH
    New video posted. Finalized the ride height, included a long cold start for those who wanted to hear it run, and gave a preview of the next upgrades.
  12. Likes jrcuz liked this post
  13. #47
    Jan 2022
    Seven Hills, OH
    New video posted. I centered the steering wheel to the steering rack and then set the front toe. Enjoy!
  14. Likes jrcuz liked this post
  15. #48
    Apr 2021
    Great videos. I am working on updating a MK 1 as well and I was curious about the part number for the steering shaft grommet you are using. Thanks!
  16. #49
    Jan 2022
    Seven Hills, OH
    Thanks for the feedback.
    Grommet that I found as being the best option is Help/Dorman part number 42344. Hoping to have it installed for the next video.
    https://www.amazon.com/dp/B000C5I49C...roduct_details
  17. #50
    Jan 2022
    Seven Hills, OH
    New video posted. Finishing up the alignment stuff, relocating some wires, fixing the speedo cable, looking at options for sealing the steering shaft, and a few tips regarding the steering wheel center piece and the wheel centers. Enjoy!
  18. Likes jrcuz liked this post
  19. #51
    Jan 2022
    Seven Hills, OH
    New video posted. I installed the Maximum Motorsports clutch pedal height adjuster and firewall cable adjuster.
  20. Likes jrcuz liked this post
  21. #52
    Jan 2022
    Seven Hills, OH
    New video posted. Checked and tightened the wheel bearings and started adding gauges. Enjoy!
  22. Likes jrcuz liked this post
  23. #53
    Jan 2022
    Seven Hills, OH
    New video posted. The 5 center gauges are all installed and working. I installed Auto Meter Cobra gauges - mechanical oil temp, mechanical water temp, clock, fuel gauge, and voltmeter. I used the oil level sensor bung with an adapter for the oil temp sensor. Also changed the oil and filter.
  24. Likes jrcuz liked this post
  25. #54
    Jan 2022
    Seven Hills, OH
    New video posted. Found a gas cap that fits under the filler cap. Installed Herb’s door panels. Also polished up some bright work. Enjoy!
  26. Likes jrcuz liked this post
  27. #55
    Jan 2022
    Seven Hills, OH
    Been a while since I have updated anything. The weather turned on us here and the car is now put away for the winter. I will be posting some videos this winter as I do have projects/work in the pipeline, but have been side-tracked with my other project car trying to complete an engine swap with it. More to come.
  28. #56
    Jan 2022
    Seven Hills, OH
    Yesterday was the one year anniversary of this car being dropped off at my house. Crazy how time files. Still working on my MR2 engine swap project, once done, Cobra work will resume. A lot on the to do list.
  29. #57
    Jan 2022
    Seven Hills, OH
    Memories, quick video of my first drive (coming home).
    https://youtu.be/B7gBPDiCPK4
    On another note, ordered Edelbrock Pro Flo 4 setup yesterday so there is going to be a lot of change coming to this car over the next few months.
    Enjoy!
  30. Likes jrcuz liked this post
  31. #58
    Jan 2022
    Seven Hills, OH
    Posted a video with an update on changes that are in the works for this year including installing an Edelbrock Pro Flow 4 setup.
    https://youtu.be/l_O8kxbJwyQ
  32. Likes jrcuz liked this post
  33. #59
    Jan 2022
    Seven Hills, OH
    Back to work on my car. Pulled out the Ford EFI and started the install of my new Edelbrock Pro Flow 4 setup.
    https://youtu.be/Tt4azabqk8E
  34. #60
    Jan 2022
    Seven Hills, OH
    Put together an update. Many new parts received/on order:
    https://youtu.be/yJeracZ2A2k
  35. #61
    Jan 2022
    Seven Hills, OH
    Let the fun begin. Attempting to install reproduction 427 S/C dash in my FFR MK2 Cobra.
    https://youtu.be/ZB5G7VnAi8o
  36. Likes jrcuz liked this post
  37. #62
    Jan 2022
    Seven Hills, OH
    Getting back to work. De-loomed and started dieting the factory Mustang wiring that has been in this car for over 20 years. Lots of progress made, more to come. Then comes time to get the Edelbrock Pro Flo 4 up and running.
    https://youtu.be/QlCtH_sN5do
  38. Likes jrcuz liked this post
  39. #63
    Jan 2022
    Seven Hills, OH
    More de-looming work on the harness. Crazy how much I can remove.
    https://youtu.be/4oYn1_q29a8
  40. Likes jrcuz liked this post
  41. #64
    Jan 2022
    Seven Hills, OH
    Finally finish removing all the I can from the main harness. Time to start reinstalling.
    https://youtu.be/b4vOF3slsYg
  42. Likes jrcuz liked this post
  43. #65
    Jan 2022
    Seven Hills, OH
    Finished re-looming and reinstalling the rear harness. Now on to the Edelbrock Pro Flo 4 EFI install.
    https://youtu.be/j3kbtHTcijw
  44. Likes jrcuz liked this post
  45. #66
    Jan 2022
    Seven Hills, OH
    New video posted, had to find a more permanent mount for the Herb's panels, started wiring in the Pro Flo 4, and new parts have arrived for the car.
    https://youtu.be/itdKRoGSnoM
  46. Likes jrcuz liked this post
  47. #67
    Jan 2022
    Seven Hills, OH
    New video posted, started installing the reproduction 427 S/C dash from cobra performance.
    https://youtu.be/CTFlNNoT-6k
  48. Likes jrcuz liked this post
  49. #68
    Jan 2022
    Seven Hills, OH
    New video posted. Started installing the throttle setup on my Edelbrock Pro Flo 4 using Forte linkage and Thompson pedal.
    https://youtu.be/wFTHlF9_2NM
  50. Likes jrcuz liked this post
  51. #69
    Jan 2022
    Seven Hills, OH
    Finished the install of the mechanical throttle linkage and throttle pedal. Happy with the results.
    https://youtu.be/8Sm5-MhVXOk
  52. Likes jrcuz liked this post
  53. #70
    Jan 2022
    Seven Hills, OH
    Back to wiring on my MK2. Almost ready to start installing the S/C dash and gauges.
    https://youtu.be/F8v3M7C9trk
  54. #71
    Jan 2022
    Seven Hills, OH
    Now that the wiring is wrapped up, I completed the final customization to install the 427 S/C dash and installed the new dash cover.
    https://youtu.be/pHTm4QkcTjE
  55. Likes jrcuz liked this post
  56. #72
    Jan 2022
    Seven Hills, OH
    Bouncing between putting the dash together and getting back to work on the engine prep/cleanup.
    https://youtu.be/7QKskEDd64Q
  57. Likes jrcuz liked this post
  58. #73
    Jan 2022
    Seven Hills, OH
    Fun task of notching/customizing the turkey pan to fit the large diameter distributor. See what I did here.
    https://youtu.be/tlKSEoPxLAg
  59. Likes jrcuz liked this post
  60. #74
    Jan 2022
    Seven Hills, OH
    One step forward, two steps back. Fixing stripped bolt holes, water pump issues/differences, and nord locks on the exhaust manifold bolts.
    https://youtu.be/7fMo0jIfzh0
  61. Likes jrcuz liked this post
  62. #75
    Jan 2022
    Seven Hills, OH
    If it’s not one thing, it’s another. Ford water pump variances bites me with my water pump replacement.
    https://youtu.be/JLmGt9JpdFk?si=js8Hr2PwopivRFO6
  63. Likes jrcuz liked this post
  64. #76
    Jan 2022
    Seven Hills, OH
    Progress and planning on my Cobra project. Dash is done and I put together a game plan for the remaining engine bay items.
    https://youtu.be/zzLfUK92zfI?si=hOw8IWROXkL15vm2
  65. Likes jrcuz liked this post
  66. #77
    Jan 2022
    Seven Hills, OH
    Planning and buying parts for multiple systems on my Cobra project. Slowly, but surely making progress.
    https://youtu.be/1aJWwjP5Mfk?si=hMsOSLsfoOb5w3Yq
  67. Thanks Geoff H thanked for this post
    Likes Geoff H, jrcuz liked this post
  68. #78
    Jan 2022
    Seven Hills, OH
    More progress - fuel system, ignition coil, finally a belt that fits, and wiring in the fuel pump relay.
    https://youtu.be/ntx7Gw0kvNQ?si=QezBX2LgH9NCiQX0
  69. Likes jrcuz, Geoff H liked this post
  70. #79
    Jan 2022
    Seven Hills, OH
    More progress on my Cobra project. Fuel system is done, on to the cooling system. Unfortunately came across a few roadblocks.
    https://youtu.be/9vNzbX2YIWY?si=tCpwS3lo6AedZE4v
  71. Likes Geoff H liked this post
  72. #80
    Jan 2022
    Seven Hills, OH
    Progress on the Cobra, it now has a FE surge tank and looks so right.
    https://youtu.be/hSKEjThxAwQ?si=7MJ9M5JVp4CAtH7u
