looking at the manual it says to bolt the sidepipe brackets through the 2x2 square tube and use lock nuts on the end of the bolt in the foot boxes. do people hit their heels on the bolt ends? do you carpet over these? is there an acceptable alternative like rivnuts in the 2z2 instead of a through bolt?
thanks
JJ
No sure but I think the bolts run parallel to the ground and floor. This puts them through the 2x2 tube from front to rear not up & down.
But then I'm just guessing.
Jim
You drill the hole then slide the bolt through pointing back toward the seat pan. The nut and rubber grommet are under the car. The only part in the footbox is the head. I carpeted over it and never thought about it again.
MK4 #10008 - Ordered 10/06/20, Delivered 03/03/21, First Start 7/22/21, First Go Kart 7/24/21
Paint by Metal Morphous 5/14/22, Legally registered 6/8/22, Graduated 7/20/22
Build Thread https://thefactoryfiveforum.com/show...been-delivered
Complete Kit, Ford 306, Sniper/Dual Sync, T5, Hydraulic clutch
I copied Edwardb and used 5/16 nutserts rather than drilling all the way through the 2" tubes. You can read about it in his build thread here. Turned out extremely solid and nice not to have the bolt heads in the footwell.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
Railroad's design is really nice for adjustability; my approach is adjustable but with washers in the vertical direction. I put two Rivnuts into the bottom surface of the 2 x 2 tube and used a piece of 2x2 angle iron with a slot machined into mount the FFR hardware. The slot gives you in/out, washers under the angle iron give you up and down.
Mk 3.1 #6616 Complete Kit, July 2008 Start, Gromm Racing 347, TKO 500, IRS, Carmine Red / Wimbleton White
Mk 3.1 #6756 Complete Kit, May 2016 kit completion, Smeding Alum. 427 Stack Injection, TKO600, Custom Silver/Blue (SOLD)
Lot of interesting approaches listed here. I kept it simple and drilled through both sides of the 2x2. Unless you put your head in the foot box, you can't see the bolt head. Because the bolt head is smooth, there is really no risk of injury. If you decide to use floor mats they cover everything up and it is a non-issue.
