Results 1 to 5 of 5
Thread: Steering shaft gemoetry ????
    Sep 2022
    Huntington, IN
    Right now my steering shaft comes through the firewall between the brake and clutch pedal. It looks like it would be a better geometry if it came between the brake and gas pedals. Anyone know a reason why not to move it? It sure would change the severe angle of the steering shaft.
    Oct 2022
    I would think that if you did that you would have the exhaust and possibly the engine in the way.
    I have a Gen 3 Hemi in mine and I have to have an extra universal and bearing over on the diagonal frame tube to get around the headers.
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Dgc333 View Post
    Running a Small block Chevy and it sure looks like more than enough room.. i'll go study it somemore
    Sep 2022
    Huntington, IN
    It appears you are correct.. there may be a slight chance it would clear but I don't think it's worth finding out
    May 2018
    Pinckney, MI
    Binding Check
    I have the Gen 2 33 with power steering. Between the steering wheel and the power unit works fine as long as you get the 90 degree phase shift steering shaft. The main issue with the linkage is that between the power steering and the rack the ujoints are very close and have too sharp an angle. Any binding there and the joints will wiggle their way to being loose. It can't be fixed by tightening something, you need to play with the joints and spacing to get them as far apart as possible. I also rotated the rack a bit (spacer under the lower mount) to get a better angle.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
