0
0
Reversing frame mods made to a gen 3 roadster
I just acquired a 2007 gen 3 roadster. The previous owner attempted to lower the body. He got as far as cutting some tubes. Where can I find some gen 3 frame diagrams or pictures so I can rebuild the frame to original specifications. The back seems fairly straightforward as there are stubs left that I can use as guide. Not sure about the front. I see that the front body mount struts welds have been ground, but can’t tell if the tubes have been modified. My plan is too strip it back to just frame, restore the frame, and then get it re-powder coated.
