Results 1 to 5 of 5
Thread: Wiring!!!
    Dec 2012
    Abbeville,SC
    Wiring!!!
    Just a picture of my tangled up mess that’s about to come out. It’s an old donor harness that’s been partially dieted.
    It’s one of those projects that’s escalated. I’m one of those that says “ while I’m here let me do this”. It’s turned into a 2 year procrastination project.
    FFR# 3247,3535,3730,3951,4338, and 5665. Currently own 5665.
    Been there many times. some of that donor wiring is sol old it might be worth buying a new harness.
    Dec 2012
    Abbeville,SC
    Yep Mike I purchased a brand new harness. I've been here many a time as well.
    Purchased many times from you and I'll be in touch shortly again. Upgrades!!!!
    I am an OG member on the other forum and I don't post here much.
    Senior Member ggunter's Avatar
    Jun 2020
    Rising Sun , Md.
    The frustration factor alone makes it worth buying a new harness. Smart move. Trying to navigate through that old harness would drive you nuts.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
    Jan 2021
    I used the supplied FF Ron Francis harness on my Roadster and installed it pretty much as supplied and shortened the runs where required. If I was to do it over again I'd open up the harness and completely remove what's not needed and add what needs to be added, it seems like it would be a daunting task but would make a cleaner install and may prevent you from having to run separate lines beside the RF harness. There are posts from builders with more experience than I who have done this in case you want to look into it further..
    2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23.
