For the guys that swapped to the QA1 DD403 front shocks, what springs did you go with?
I'm running 300# 9" long springs in the front with my QA1 DD403 coil overs. Very comfortable ride.
Jim
I did pretty much the same as Jim, QA1’s
Front - 9” 300 lbs
Rear - 12” 275 lbs
I did get some 8” 250 lbs springs from Jim that I decided not to use.
I’ll be giving them away and then selling the Koni coilovers that came with my hotrod.
(The Koni’s were sold)
I went down to 220 on the fronts. A lot nicer than the original... I left the IRS springs as is.
All I do is cruising. If you want to AutoX, you actually need to go the other way!
Gen 1 '33 Hot Rod #1104
So what's the deal going with shorter springs? Aren't these supposed to be 10" springs?
The springs touch if you lower the car on the longer springs. I’m running 800/450 springs now and all 7”
Springs all depend on the weight of the car. The back won’t change much but the front can depending on the size of the engine and if it cast iron or aluminum.
No problem, for some reason FFR's spring were short little things (8"), that's why in the rear most builders have their Koni's adjust almost to the top of the threads to get the right ride height. Even in the front the 8" seems too short which is why I switched to the 9".
Jim
They sent me 9" fronts and 10" rears. I had to wait a couple of months for the front springs to show up.
You’re not wrong.. but after 2.5 years of tweaking I finally have a car that plants the outside tire correctly.. which equals speed! First in class last week
What is the advantage of longer springs assuming the same spring rate?
I got daring yesterday and took my Speedstar for a drive out of the neighborhood. It gave me a chance to get up to about 50 mph and go through the gears. One thing I noticed was the back end was pretty jarring, the front didn't seem bad.
Since the spring is way up the body of the shock there is plenty of room for a longer spring. Maybe a progressive wound spring or dual rate springs.
Also, what are folks running for air pressure on the hot rod. Saw a post where the recommended air pressure for the roadster is 22-23 psi. Don't know how much heavier the the hot rod is but based on this I should have a lot less than the 35 psi currently in the tires.
Aren't the Koni springs a 2.5" spring? Same as the QA1? If that's the case, Can't I use the Koni 400# on the QA1 as starting point?
400 in the front are pretty stiff.
I changed my front and rear springs, see post #3.
I still have 8” 250 lb springs for free if you or anyone else wants them.
QA1 recommends a 10" for the DS403 shocks. The ones I have from FFR are 8" .. should I go with 9" or 10"? Keep in mind, i'm installing these inverted with the more cone shaped QA1 top retainers 9018-113
A little more measuring, I can see with the std shock top retainer that a 10" would be correct, with the more tapered top retainer the 9" should be the ticket.
