![Boig Motorsports](https://thefactoryfiveforum.com/attachment.php?attachmentid=181712&d=1679150850)
Seatbelt Options - 3 Point Racing Belts
Anyone have seatbelt advice? My 818 has Subaru sedan belts installed, but the retraction/extension is slow and sloppy - it seems like the angles just don't work out. I'm considering 3-point retractable racing belts like the Corbeau 3-Point, 2" Retractable Harness - has anyone tried something like this?
Thinker of thoughts
Can't help you with the racing belts, but I also found the "stock" setup is not very good. Agree the angles aren't great and I've had the passenger one not retract at all once and was a bit of a pain to get it working. I just put some universal retracting ones (shoulder and lap) in an older car (British car and belts from a British car company) that work very well. I'm going to look into putting a set like that in the 818 if I have any more issues with the stock ones.
Rick
Thinker of thoughts
Dave 53
Yes, that is how I will do it if/when I replace mine. Forget about hiding the retraction stuff inside a panel so it doesn't work properly.
![Stewart Transport](https://thefactoryfiveforum.com/attachment.php?attachmentid=40533&d=1428868052)
