Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Differential mounting bolts?
    Oct 2022
    For my project, I have received the IRS for my Coupe 65 from FFR.
    In the manual, it talks about the "smaller/Shorter bolts" and the larger/longer bolts", but what are these fasteners?
    I don't have any prepackaged nuts and bolts with my new differential from FFR.
    Are there part numbers for these? Description of the fasteners?
    Understandably, I don't want to just guess.
    Chris Nicholls
    Mar 2021
    Ohio
    Sounds like you are missing the hardware pack.
    17157
    IRS FASTENERS
    FASTENERS, NUTS AND BOLTS, SIZES AND TYPES BAGGED INDIVIDUALLY AND LABELED WITH FFR # AND FASTENER SIZE THEN MASTER BAGGED AND LABELED "FFR# 17157, IRS FASTENERS"
    1.00
    EA
    10834
    1/2"-13 NYLON LOCK NUT
    LOCK-NUT, NYLON , GRADE 5, ZINC, 1/2"-13
    4.00
    EA
    12386
    1/2"-13 x 3.25" BOLT
    SCREW, HEX HEAD CAP, GRADE 5, ZINC, 1/2"-13 x 3.25"
    2.00
    EA
    12332
    1/2"-13 x 4" BOLT
    SCREW, HEX HEAD CAP, GRADE 8, 1/2"-13 x 4"
    2.00
    EA
    13166
    3/4"-16 LFT HAND JAM NUT
    NUT, JAM, ZINC, 3/4"-16 LEFT HAND THREAD
    2.00
    EA
    12387
    5/8" WASHER
    WASHER, FLAT, USS, ZINC, 5/8"
    2.00
    EA
    15216
    5/8"-11 MECH LOCK-NUT
    LOCK-NUT, AUTOMOTIVE, GRADE 8, ZINC, 5/8"-11
    4.00
    EA
    15937
    5/8"-11 x 2.25" BOLT
    SCREW, HEX HEAD CAP, GRADE 8, ZINC, 5/8"-11 x 2.25"
    2.00
    EA
    1.88
    5/8"-11 x 4.25" BOLT
    SCREW, HEX HEAD CAP, GRADE 8, ZINC, 5/8"-11 x 4.25"
    2.00
    EA
    16040
    M10 x 20MM SOCKET HEAD
    SCREW, SOCKET HEAD CAP , GRADE 12.9, ZINC, M10-1.5mm x 20mm
    4.00
    EA
    15961
    M10 x 25MM SOCKET HEAD
    SCREW, SOCKET HEAD CAP , GRADE 12.9, ZINC, M10-1.5mm x 25mm
    10.00
    EA
    14759
    M14-2.0 FLANGED LOCK NUT
    LOCK NUT, DEFORMED THREAD, FLANGE, GRADE 10.9, ZINC, M14x2.0
    2.00
    EA
    15962
    M14-2.0 x 100MM FLNG HEAD
    SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, CLEAR ZINC, M14-2.0 x 100MM
    2.00
    EA
    15936
    M14-2.0 x 80MM FLNG HEAD
    SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, ZINC, M14-2.0 x 80MM
    2.00
    EA
    14925
    M16-2.0 x 110MM FLNG HEAD
    SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 110MM
    8.00
    EA
    15963
    M16-2.0 x 130MM FLNG HEAD
    SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 130MM
    2.00
    EA
    15909
    M16-2.0 x 90MM FLNG HEAD
    SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 90MM
    2.00
    EA
    14515
    M16-2.0MM FLANGED LOCK NUT
    LOCK NUT, FLANGE HEX HEAD, GRADE 10.9, SILVER ZINC, M16-2.0
    12.00
    EA
  3. Thanks ChrisNicholls thanked for this post
    Norton, MA USA earth
    The IRS is a separate hardware pack.
  5. Thanks ChrisNicholls thanked for this post
