Differential mounting bolts?
For my project, I have received the IRS for my Coupe 65 from FFR.
In the manual, it talks about the "smaller/Shorter bolts" and the larger/longer bolts", but what are these fasteners?
I don't have any prepackaged nuts and bolts with my new differential from FFR.
Are there part numbers for these? Description of the fasteners?
Understandably, I don't want to just guess.
Chris Nicholls
Sounds like you are missing the hardware pack.
17157
IRS FASTENERS
FASTENERS, NUTS AND BOLTS, SIZES AND TYPES BAGGED INDIVIDUALLY AND LABELED WITH FFR # AND FASTENER SIZE THEN MASTER BAGGED AND LABELED "FFR# 17157, IRS FASTENERS"
1.00
EA
10834
1/2"-13 NYLON LOCK NUT
LOCK-NUT, NYLON , GRADE 5, ZINC, 1/2"-13
4.00
EA
12386
1/2"-13 x 3.25" BOLT
SCREW, HEX HEAD CAP, GRADE 5, ZINC, 1/2"-13 x 3.25"
2.00
EA
12332
1/2"-13 x 4" BOLT
SCREW, HEX HEAD CAP, GRADE 8, 1/2"-13 x 4"
2.00
EA
13166
3/4"-16 LFT HAND JAM NUT
NUT, JAM, ZINC, 3/4"-16 LEFT HAND THREAD
2.00
EA
12387
5/8" WASHER
WASHER, FLAT, USS, ZINC, 5/8"
2.00
EA
15216
5/8"-11 MECH LOCK-NUT
LOCK-NUT, AUTOMOTIVE, GRADE 8, ZINC, 5/8"-11
4.00
EA
15937
5/8"-11 x 2.25" BOLT
SCREW, HEX HEAD CAP, GRADE 8, ZINC, 5/8"-11 x 2.25"
2.00
EA
1.88
5/8"-11 x 4.25" BOLT
SCREW, HEX HEAD CAP, GRADE 8, ZINC, 5/8"-11 x 4.25"
2.00
EA
16040
M10 x 20MM SOCKET HEAD
SCREW, SOCKET HEAD CAP , GRADE 12.9, ZINC, M10-1.5mm x 20mm
4.00
EA
15961
M10 x 25MM SOCKET HEAD
SCREW, SOCKET HEAD CAP , GRADE 12.9, ZINC, M10-1.5mm x 25mm
10.00
EA
14759
M14-2.0 FLANGED LOCK NUT
LOCK NUT, DEFORMED THREAD, FLANGE, GRADE 10.9, ZINC, M14x2.0
2.00
EA
15962
M14-2.0 x 100MM FLNG HEAD
SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, CLEAR ZINC, M14-2.0 x 100MM
2.00
EA
15936
M14-2.0 x 80MM FLNG HEAD
SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, ZINC, M14-2.0 x 80MM
2.00
EA
14925
M16-2.0 x 110MM FLNG HEAD
SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 110MM
8.00
EA
15963
M16-2.0 x 130MM FLNG HEAD
SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 130MM
2.00
EA
15909
M16-2.0 x 90MM FLNG HEAD
SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, SILVER ZINC, M16-2.0 x 90MM
2.00
EA
14515
M16-2.0MM FLANGED LOCK NUT
LOCK NUT, FLANGE HEX HEAD, GRADE 10.9, SILVER ZINC, M16-2.0
12.00
EA
The IRS is a separate hardware pack.
