Results 1 to 11 of 11
Thread: I need a radiator!!!!!
    Senior Member ggunter's Avatar
    Jun 2020
    Rising Sun , Md.
    Well, it lasted 10,000 miles and now its leaking where the core is attaches to the tank. Not a very good service life for a radiator. I'm sure other people have had them leak. Question is do radiator shops repair these aluminum radiators. Of course, FFR doesn't have any. Next question is there a replacement that someone else makes I can find on the internet?
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
    Pretty sure FFR has them. Did you try calling?
    I couldn't find a shop to repair mine when it leaked and fortunately, FFR had just received a shipment of them and I was able to buy a replacement. I can't help with your questions on alternatives as I never had to research it in my case.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member of the The Gateway Cobra Club
    If you are looking for a temp fix to get you by for a while, J.B. Weld sells an epoxy for radiators that might stop the leak.
    Legal: 1/30/2020
    Jun 2015
    Maumee, OH
    Michimoto makes a radiator and compatible fan that works perfect. Life time warranty as well.
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
    Jun 2020
    Rising Sun , Md.
    I checked FFR parts websites and it said out of stock. I’ll call on Monday and see if they have any.
    Fun Package
    I recently changed out my radiator and went directly to AFCO RACING to get it because Factory Five Racing did not have them in stock.
    Since I'm Dark Side Powered, I used the radiator listed below and simply had the inlet angle changed to make it perfectly fit my MK-4 Roadster.
    https://www.afcoracing.com/store.asp...-Filler-Neck--
    Be advised that my original radiator came from AFCO and they said they had the specifications for the Factory-5 radiators but it was a proprietary item.
    Personally I wish Dave Smith would allow AFCO to sell the original style radiators to Factory-5 owners if they aren't able to keep them in stock.
    Good Luck!
    Jun 2020
    Rising Sun , Md.
    I called FFR yesterday and they said they were out of stock, but some were due in "soon". I backordered one so when it does come in, I'll have a spare and swung by the radiator shop, our shop uses this morning, and he said no problem to repair. So, by the end of the week I should be back in business.
    Fun Package
    Jul 2021
    West Grove, PA
    Quote Originally Posted by ggunter View Post
    Nice! Stop up Friday - lets go for a ride!
    https://www.radiatorexpress.com/prod...221913/1333505
    Not a direct replacement as the in/out hose diameters are a bit different (I can't remember 1.5" or 1.75") but physically it fits my Coupe and I can get a spare delivered in a couple of days. I bring one along on long trips away from home.
    Gen III Coupe #17
    Member jmsrx's Avatar
    Jan 2012
    Oklahoma
    Quote Originally Posted by Dave Tabor View Post
    https://www.amazon.com/FSMOTO-Alumin.../dp/B09NVFX1P7
    I've used a couple of these but you have to change the lower hose diameter.
    Gen III Coupe #17
    20,000+ miles
    Thanks Dave!
    Gen. 3 Coupe - Coyote motor, TKO 5 speed
    Daily Driver: 2017 Ford Focus RS
