Results 1 to 11 of 11
Thread: Driver foot box
    Oct 2022
    North Carolina
    Driver foot box
    Hi again,
    I am doing the driver side foor box and have it all test fitted. The right side does not seem to be very stable where it meets the frame. I have searched through the manual and unless I missed it do not see panel that would resolve this.
    So, have I missed something or is it just like this?
    Ideas ... please?
    Mar 2022
    Attleboro, Massachusetts
    Once you drill, silicone, and rivet the tab to the round tube it will be more than strong enough. I also did two rows of rivets under the square tube and where the outside panel meets the bottom of the floor.
    Oct 2022
    North Carolina
    I was meaning the other side, the sheet metal just seems to rest it's edge in the frame rail.
    Sorry if I got them backwards
    Mar 2022
    The inside engine compartment panel that just seams to rest on top of the 4” round tube?
    Jan 2021
    Winnipeg, MB.
    I think you're describing the inner footbox AL panel that runs forward on top of the 4" tube beside where the accelerator peddle is. This panel, when fitted correctly, kinda rests on top of the 4" tube, I agree with you it's not very well supported. Some builders silicone the footbox panel to the 4" tube and Aluminium tape to seal it. My fix was to make/bend a piece of .40 Al to better connect the side panel to the 4" tube, drilled - siliconed - riveted and taped the piece on the inside of the drivers box before applying theromotech insulation. I think I read a few build blogs on this before coming up with plan.
    2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23. https://thefactoryfiveforum.com/show...4-Build-update
    Oct 2022
    North Carolina
    Yes, that's the one. If there is not anything I think I might to make something .. unless there is a reason for it to be like that.
    Oct 2022
    North Carolina
    That is what I was thinking of doing, it is good to hear that it is an accepted idea. I will feel better for it, especially with putting a throttle linkage through it.
    Thanks guys!!
    Jan 2021
    Winnipeg, MB.
    Sounds like you're cooking up an approach. Every time I fit that side panel in I seemed to get it to fit better, the alignment to the cockpit "A" panel (in front of the tranny) and the floor should be taken into consideration as they all converge. I'm better at puzzles after this experience. LOL There was a good discussion on Mechanical Throttle linkage this week in case you are thinking that way..
    Member Sarcasticshrub's Avatar
    Dec 2021
    Mariposa, CA
    Made a patch panel out of some leftover metal flashing (the green you see there) and silicone and rivets to hold it in place. That with the heat/sound barrier and carpeting should do the trick.
    Senior Member cobrajj's Avatar
    Murrieta, Ca
    Mk3.1 Complete kit #6846 Delv. 12/20/08-- Finished 2/11/11, 89 302 EFI,T-5, 3-Link, 17" Halibrands, Nitto 555 245-315 tires, widened drivers footbox w/ dead pedal, extended passengers footbox,Sapphire Blue Met & Wimbledon White stripes,radiator stone guard shield, Build blog http://jimsffrcobrabuild.blogspot.com/
    Oct 2022
    North Carolina
    Think I have the plan now. Thanks for all of the input!
    ... and yes, this may be the best puzzle in the world!
  12. Likes Jeff_J. liked this post
