Likes Likes:  2
Results 1 to 3 of 3
Thread: Sniper EFI 2 - 427w Stroker, 347 Engines
    Oct 2023
    We have a few of the Sniper EFI 2 Throttle body systems in cue for future Engine builds. Anyone want to pre-order your custom crate engine with one of these units installed, Drop us a call or email . Some of the advantages of the Sniper 2 over the original is direct compatibility with the 4R70W 4 Speed or other Transmissions. So no need for an extra ECU, less radio frequency Noise pickup, larger touch display, more tuning options. Better pedal feel response etc. improved throttle linkage. Still Self Tuning. 302 - 347 stroker - 427w strokers.
    www.mustangengines.com
    Coyote / Godzilla packages for the MKIVs , Hot Rods and Coupes.
    https://www.mustangengines.com/produ...yote/godzilla/
    A couple of the "Ultra thermostat housing" setups for the small blocks in stock
    https://tdmotion.com/product/427w-fo...t-housing-kit/
  2. Likes FF33rod, CaptB liked this post
    Senior Member MPTech's Avatar
    St. Louis, MO
    Quote Originally Posted by TD Performance View Post
    Error: Page not found
    Senior Member jayguy's Avatar
    Las Vegas
    Links were copied exactly as you see, with the ... in the middle, thats why they don't work.
    Try these:
    Coyote/Godzilla - https://www.mustangengines.com/product-category/coyote/
    Ultra thermostat housing kit - https://tdmotion.com/product/427w-fo...t-housing-kit/
