Likes Likes:  2
Thread: Tight Clearance between Coyote Accelerator and steering shaft
    Jun 2022
    I've got it all installed and the plastic on the accelerator trimmed right to the edge of the mount. But man that's close. Column seems to rotate ok. Should I move the mount or try as is?
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    Nov 2018
    CT
    I had the same issue. I trimmed the plastic as much as I could. I also loosened all of the bolts on the steering shaft bearing going through the footbox and moved the steering shaft as far away as I could with the limited play I had. It was enough to give me a little more clearance than you are showing in that picture.
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I had a little more clearance until I mounted the Russ Thompson indicator which unfortunately moved the steering shaft closer to the accelerator pedal. I ended up with similar clearance to what you have and I haven't had any interference issues after 700 miles.
    Jun 2022
    Quote Originally Posted by Tbev View Post
    interesting, I hadn't thought of this, thx
  5. Likes Tbev liked this post
    Dec 2021
    SE Arkansas
    I also trimmed the plastic some.
    Ken
    MK4 #10476, complete kit, Gen 3 Coyote, TKX with 0.68 overdrive, 3.55 Mustang IRS, 18" rims, dual rollbar, Carbon fiber dash,
    Ordered 12/18/2021, Deliverd 9/24/2022, First Start 6/24/2023, Licensed 6/2024
    Nov 2019
    Charlotte, NC
    Yep, I had to trim a LOT as well and it barely clears. But...10 thousandths or 10 feet....clearance is clearance. Send it!
  8. Likes toadster liked this post
  9. #7
    Folsom, CA
    trimmed the heck outta mine as well
    the upper portion I had to grind down flat, even more than shown in my photo below - it's flush against the footbox wall
    Todd
