Likes Likes:  2
Results 1 to 14 of 14
Thread: Wiper Motor Mount
    Oct 2020
    Wiper Motor Mount
    About to mount my wiper motor. Seems straight forward but the firewall is thin and with the weight of the motor it seems like it will not be very sturdy once mounted. I was thinking about adding an aluminum plate to screw through on the back of the firewall to add rigidity. Any suggestions I’m not thinking of? Something I’m missing here?
    The motor isn't creating much stress from operation. I mounted mine with nothing more than the firewall aluminum and some washers on both sides.
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I made some support brackets out of 1/8" aluminum right angle I got from Home Depot. I used the brackets because I added some spacers to the wiper motor to get better alignment with the cable drive and wiper transmissions. I don't think I would have bothered with the brackets if I mounted the motor directly to the firewall. I did need to trim down the upper bracket (not pictured) to allow the bulb seal to properly seat on the top of the firewall. Not that this makes a difference, but I used the Specialty Power Windows wiper kit.
  4. Likes Pmieras liked this post
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    I mounted mine so that the lower bolt goes through the 3/4" frame tube. The upper bolt (on the right side viewed from the engine bay) just goes through the thin firewall aluminum. I did use a large washer on the inside of the firewall to spread the load.
    https://thefactoryfiveforum.com/show...l=1#post525716
    Darryl [dbo_texas]
    Member Pmieras's Avatar
    Apr 2023
    San Tan Valley, Arizona
    I like it
    Jun 2020
    Rising Sun , Md.
    I just riveted a piece of aluminum on the back side of the dash panel to stiffen it up. It worked quite well. I think the thicker dash panel would not need any stiffening.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
    Sep 2011
    Minneapolis, MN
    I used this bracket from McMaster (3176T66), which I think gives a solider mount and better look, particularly if you paint the motor housing and U bolt black. I did put an aluminum backing plate behind the firewall. But Papa's right, there's not much stress that's going to be placed on the panel by the static or dynamic forces at work here.
    Untitled by John Ibele, on Flickr
    This is the bracket that came with my kit.
  10. Likes John Ibele liked this post
  11. #9
    Fairfax Station VA
    The thicker aluminum of ffmetal.com's firewall forward kit provides plenty of support.
    I WISH I'd used riv-nuts to receive the mounting bolts. If I ever have to change the motor, it'll be a two person job with through-bolts.
    MK IV Roadster #8631
  12. #10
    Oct 2020
    Got mine installed thanks for the advice excellent as always. The aluminum plate makes it very strong. Have not run it yet obviously but it’s solid. Posting couple pics in case others find this thread and think it’s helpful.
  13. #11
    Oct 2020
    Junior Member eljessup65's Avatar
    Apr 2023
    Mount Pleasant, SC
    Quote Originally Posted by zanman View Post
    Thanks for the install pics. Who makes the wiper kit in the photos?
    MkIV Roadster, Chassis number 10735, Ordered 5/10/23. Delivered 10/1/23. Complete Kit, IRS, 427W, TKX
  15. #13
    Feb 2018
    Austin, TX
    Quote Originally Posted by eljessup65 View Post
    https://www.factoryfiveparts.com/155...-kit-roadster/
    Darryl [dbo_texas]
  16. #14
    Apr 2023
    Mount Pleasant, SC
    I see, you used a T-Bolt type clamp instead of the Muffler type clamp. Much better!
