0
0
Perplexed with a Coyote Wiring Issue
I apoligize in advance, and especially to Paul, for posting a question about the pigtail wiring from the Ford Controls Pack wiring harness to the RF harness.The problem may lie in the different versions of the instructions (mine came with version IS-1850-580, not the version IS-1850-0678 which everybody seems to link to). Additionally, my engine is a Ford Aluminator, though it is based on the Coyote and Ford says the wiring is the same. My question - My control pack pigtail has 5 wires coming out of it though all of the instructions speak to as many as 6 or 7. As has been pointed out many times, I followed the instructions and connected the dark green wire on the pigtail to the RF fuel pump circuit; the light blue wire on the pigtail to the RF blue EFI Crank Power wire; the light green ignition trigger wire to the RF orange EFI and the black ground to chassis ground. According to the instructions, there are supposed to be other wires that are not used because they are for paddle shifters (wire colors GY, GY-VT and BU.) My pigtail does not have any of these wires, however, it does have a red wire that is labeled HAAT. On the instructions I have, it indicates to "Connect this lead to locations as needed: 1) the input node of the ignition cylinder." These instruction also identify 2 other wires from the pigtail that are supposed to connect to the MIL. I don't have either of these wires on the pigtail, but my MIL is separately wired in the Controls Pack Harness along with the diagnostic port from a branch just before the pigtail.
I hope this question is clear enough for the experts. My bottom line question is what do I do with the HAAT red wire coming off the pigtail and should I be concerned that these other wires are not present.
Thank you all for your help.
David...
MK4 Roadster Delivered 11/28/2022
Ford Racing Aluminator A52XS; T56 Magnum
IRS; Billet IFS; QA1 Double Adjustable Shocks; Wilwood Big Brakes from Gordon Levy
Slowly building my dream
HAAT stands for hot at all times. You dont need to connect it to anything. Its just an extra power wire if you wanted to power something that came on with the control pack. Tape it off and ignore it. Your harness is a GEN 2 harness in order to run the Aluminator. I just did one. thats why the check engine light is already wired.
Not to worry. Different revisions of the coyote wiring harness have had different numbers of wires in the pigtail. IIRC, the original pigtail had as many as 12 wires in the pigtail, and they've been reduced over time. What you've listed is what you need. My MIL wires were also wired separately from the pigtail and were wired to an LED. I removed it and wired a different LED in the dash. What you've described sounds normal. The HAAT wire is just that - a wire that has +12V at all times. It's useful for items like the dash clock (if you're installing that) so that it has power at all times.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
