A couple of updates. Thanks to Greg for pointing out some issues with the front end assembly. I have everything corrected and reassembled (with the exception of the upper ball joints). I also trimmed the UCA arms in the back as suggested in other threads, I hated doing it but a half hour with a dremel and a sander and they cam out fine.
The old ball joints pinched and created tears due to the incorrect installation. Front Boots.jpg
I have the dash re assembled and everything wired in. After completing this the horns quit working. I naturally went back through the dash assuming I had somehow messed this up.... No change after reassembly.
I finally (after an hour or so) chased this to a bad ground in the Ron Francis harness. The leg for the horn ground was not soldered well to the ground in the front harness. I ended up just grounding the horns directly and removing the leg as it allowed me so insulate the main ground wire better. Bad Ground Hord.jpg
