Likes Likes:  7
Thread: Dyno Results for My Gen2 Coyote Roadster
    Oct 2020
    Utah!
    Thought I'd post what I got during my tune done on a dyno. Not sure how this compares to what others have seen. Max HP was 402 at the wheels. Have seen numbers around 375 at the wheels for stock GTs.
    Coyote Gen2, GasN headers with touring pipes, 91 octane tune, power steering.
    MKIV #8414 - Complete Kit - Gen 2 Coyote - MT82 6 Speed - Wilwoods - Moser 3.55 Rear
  2. Likes Ducky2009, Railroad, CaptB, toadster liked this post
    Jun 2023
    Tonganoxie KS
    That's great. Do you mind sharing location and who did the tune? I would like to do the same for my car when complete
    On a roll Al_C's Avatar
    Wheaton, IL
    I think your results are good. My Gen II tune resulted in 389 at the wheels, but I'm restricted by shorty headers and J-pipes. I believe Nuhale's tune resulted in about 411 at the wheels, but it's probably higher now that he swapped out his intake. I believe your 402 number is a good spot to be!
  5. Likes toadster liked this post
  6. #4
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    I can't find my dyno sheet from last year but I believe I'm around 435rwhp on a 93 tune.
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Covid
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55 [/B]
  7. Thanks Al_C thanked for this post
    Likes Al_C liked this post
  8. #5
    Oct 2020
    Utah!
    Quote Originally Posted by kirby View Post
    I found a local shop here is Salt Lake to run it. Their name is Premier Complete Auto Care and they have a tuner come in a few times a week. They are a performance shop. The name sounds like a lube and brake shop.
  9. #6
    Jun 2023
    Tonganoxie KS
    Thanks for sharing. That's higher elevation than I will be
  10. #7
    Folsom, CA
    I did mine last friday it's a Gen3 with Tremec TKX and GASN touring pipes, 91 Octane, PS, PB, A/C, FFR equal length headers
    Todd
  11. #8
    Wheaton, IL
    Great results!
  12. #9
    Aug 2019
    Verona ILL
    Tune and dyno prior to full blow driving. Gen 3 w TKO600, FFR Coyote ball headers and FFR pipes, 3:55 gears HP Tune we ended with 457HP at the wheels 400lbs of torque. Ran it to 7300 RPM.
    Mk4 9735 complete kit delivered 11/29/19 Gen 3 Coyote, Tremec TKO 600, Moser 3.55 First start June 25, 2020 First Go Cart July 20, 2020
  13. Likes toadster liked this post
