I have seen a few threads on air jacks here. Seems the few who have them use Allstar as the solution. I am curious know how much lift is needed to allow the hood to open when the front airfoil from the coupe R is present.
Allstar has options with 11.75” or 15.25” stroke while Nuke performance has a 9.75” option.
Can someone measure the distance from the nose to the ground when the hood is open on a coupe without the front airfoil? I should be able to calculate from there what I will see with the air foil.
Or if someone has the coupe R with air jacks, how much space do you have under the nose when lifted? And what size Airjack did you use?
