Likes Likes:  2
Results 1 to 4 of 4
Thread: Helpful Hint for Installing Control Arms
    Dec 2022
    Hey fellow coupe builders. I wanted to provide a helpful hint for installing control arm rod ends into narrow mounting brackets. While trying to install my rear suspension, I found it difficult to jam the rod ends into the chassis brackets. Several of them were about 1/16th of an inch too narrow. So I tried to find a tool that would make the openings a little wider. I finally found this handy gadget at Advance Auto parts. It's a brake pad spreader that is operated with a 3/4 inch wrench, and made the job easy. I hope this helps anyone who is struggling with this same situation.
  2. Likes MSumners, 65 Cobra Dude liked this post
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    That's a great find/idea. There are probably a few more places that would also come in handy. Wish I would have thought of it for my build— if I remember properly, I think my tool of choice was a couple big-*** crescent wrenches.
    --jim
    Build 1: Gen III Type 65 Coupe, Gen II Coyote
    cv2065's Avatar
    Nice find! Haven't seen that one before. You can also use some simple threaded rod with two nuts and 2 washers. Easy to get in some of the small places, as you'll need to spread the ears out in just about every installation, from UCAs, LCAs and shocks.
    Dec 2023
    I just used that technique last night. Have used it several times before in this build. Cheaper than buying a tool
