Likes Likes:  2
Results 1 to 17 of 17
Thread: Heater/defroster ... worth it?
    Oct 2022
    North Carolina
    Just laying out the dash and behind it so I allow for space and routing before I go much further.
    Given that I can't do a top for a 289 is it worth putting in the heater/defroster?
    I am having difficulty in laying out how to install it.
    I am the one that will drive in the cold topless ... I am Canadian and NC is not proper cold so it makes sense to have it, especially the defrost.
    If anyone has done one for the 289 can you share insights or install pictures?
    I also assume that the install is pretty close to the 427 so the rest of you please chime in.
    Hope everyone is having Happy Holidays!
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    For what it is worth, I don't have a heater/defroster and I am in Maine. I find seat heaters are all that I need and I have had no issues driving around in the mid 40's. Although it gets plenty colder than that here, tire traction really starts to drop off and I don't have much interest in driving when it is below 45.
    Dublin, OH
    I’ll drive my roadster in the late fall to work sometimes when the daytime highs are in the 50-60s. But that means the morning temps are usually in the 30s. On those days , it’s nice to have seat heaters and a heater
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    I’ve hit heavy fog driving to events early in the morning and I’m glad I had the defoggers. Without them I would have stayed home. The heat is pretty good too. I have seat heaters which to me are a must.
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
    I created my own heater specifically for my wife's feet.
    Was it needed in my opinion? No, No, No & No.
    Does my wife like it? Yes, Yes, Yes & Yes.
    The link for my heater is listed below:
    https://thefactoryfiveforum.com/album.php?albumid=982
  6. Likes CaptB, Joel Hauser liked this post
    Let's just say I have never regretted installing a heater in my MK3.1. It doesn't get used a lot but when I need to it's wonderful to have.
    I installed controllable defog vent outlets which allows me to send more heat into the foot box areas when needed.
    Oct 2020
    Utah!
    I'm very happy that I installed the heater. I did not install the defroster and instead routed those hoses to additional heater ports. I also have a glove box. I moved the entire heater box/fan forward about two inches. Installed some brackets on heater and mounted it to the firewall. I did check clearance with the engine prior. I have a Gen2 Coyote and it fit well.
    I live in Utah and in late fall took a drive in low 50 degree weather and between the heater, heated seats and partial top it was very comfortable at 70 mph.
    MKIV #8414 - Complete Kit - Gen 2 Coyote - MT82 6 Speed - Wilwoods - Moser 3.55 Rear
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    My first year driving (well 6 months), love the heater adds comfort on the cold days.
    Forte's Axle
  10. #9
    Prescott, AZ
    The defroster is pretty much useless in an open car. The heater can be useful from time to time. I built my car in CA and we had a run from Temecula to the Stone Brewery to finish off the day. With the run often starting off around 40 degrees plus adding the wind chill factor, the heater was great to have on those cold mornings.
    Our cars really should not be driven in cold weather anyway as the tires need heat in them to generate traction. So the opportunities to use the heater are going to be limited. That said, coming home in the evening after a road trip or show, you will find the heater welcome after the sun goes down.
  11. #10
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    In addition to seat heat, I’ve wired a couple plug-ins that are compatible with the heated clothing from the motorcycle world. (Driver and passenger)
    I’m not on the road yet so can’t speak to the effectiveness but if it works for a motorcycle it should work for an open car. I would only expect to maybe use a heated vest under a normal jacket and/or possibly the heated gloves but I really wouldn’t know until I get there.
  12. #11
    Nov 2023
    I AM a motorcyclist and DO have a heated underjacket., specifically a Harley jacket. M
    This particular model is not a vest, but a very thin jacket with heat in the sleeves as well as torso area. Easily fits under my leather. Incredibly toasty.
  13. #12
    Mar 2022
    Attleboro, Massachusetts
    I just recently finished my 289 FIA build and have both the heater and heated seat options. Was driving around in the low 30s and was pretty comfortable with both on. They are both viable options to have in these cars, at least where I am in the Northeast. I did not put in the defrost vents. If you want the 289 FIA dash with the heater you will need either the dash forward extension or a blank dash to make your own layout like I did.
  14. #13
    Quote Originally Posted by 42Bfast View Post
    We sold a Canadian made heated vest for M/cycles, ATV's, Snowmobiles, etc. and the customers loved them. The one complaint was they were either full on, or full off. They were wired so you had to pull the plug to shut it off if you got too hot. Get cold again, and you needed to plug it in again, which usually meant having to pull over and stop.
    We found a small 12V rheostat that was wired in line, so you could control the power feeding to the vest, to whatever temperature you preferred. The rheostat was placed in the vest pocket, so it was handy. Buyers loved this option, and we sold tons of them.
  15. #14
    Nov 2021
    Texas!
    Quote Originally Posted by AC Bill View Post
    I have a PWM module for my heated motorcycle jacket/gloves, just links in-line with the power plug between the vehicle and the jacket.
    Rob Windsor
  16. #15
    Oct 2022
    North Carolina
    Well guys,
    Thanks so much for all of the wonderful input.
    I have read and investigated so much during this time.
    I was not going to put a heater in and at the last moment ordered the heater with the compete kit. I did not realize how it would stick into the engine area. I didn't really like that idea so much .. just me being difficult I guess.
    Since this thread started I also got thinking more and more .. I have a Porsche Boxster that I use all year and have the top down more often than not. I literally never use the heater or defroster, except on a couple of occassions. I guess it is my Canadian blood.
    I had never thought of heated seats, nor extra plug ins for heated jackets. I think I am going to try that and forgo the heater/defroster.
    That all said .. anyone want a deal on a heater/defroster?
    Again thanks so much .. I am sure I will end up with more questions momentarily.
  17. #16
    Aug 2012
    Grand Rapids, MI
    In a past life with my Superformance cars I appreciated the defroster on those early morning foggy runs like brewha mentioned. The car had a full heater system that also got used. I seldom used the top.
    Not planning a heater/defroster for this build but I'm also planning a trailer for those early morning track runs.
    Jim
  18. #17
    Jun 2023
    Quote Originally Posted by FredG View Post
    Well guys,
    Hello Fred, I may be interested in your unused heater/defroster if you still have it available. I am also in NC, but don't have your Canadian blood! Could you provide more details? Thanks SimonC.
