Thanks Thanks:  3
Results 1 to 11 of 11
Thread: Engine Accessability
    Dec 2019
    It seems like the sequence of events is to build chassis, install engine and powertrain, then drop body on top
    When you are done it looks like it is very hard to get to the engine to ever service anything after you have built it
    How common is it to pop the entire body off when doing repairs (so long as you have a hoist) ?
    If you designed it correctly at the initial build, with a few major bolts and nice quick connects for all the wiring ....has anyone done that?
    Colorado Springs
    Depends on the engine you put in. If it's a Windsor small block, it's not a big deal. Probably better access than a late model Mustang. It's pretty easy to pull the engine without even taking he hood off.
    But with a Coyote, FE, or (worse) a Lima motor, access can be quite difficult.
    Taking the body off will literally take all day and 2-3 people. If you're lucky.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Aug 2012
    Grand Rapids, MI
    I expect to remove the body when necessary.
    Jim
  4. Thanks Dave108 thanked for this post
    Prescott, AZ
    If you are doing a Coyote build, try to add accessibility features during the build.
    While I am not building a MK4 right now, I have made some mods to my 1970 Mustang Coyote powered restomod to make the engine as serviceable as possible. One example, to remove the alternator, you must rotate the alternator toward the left side frame rail. I added a notch to the frame rail in my Mustang to accommodate room for the rotation. I have a hydroboost system in the Mustang and it would be PITA, to say the least, to raise the engine off its mounts in order to remove the alternator otherwise. Other mods to consider would be to have access panels for the Wilwood master cylinders if so equipped.
    Good luck with your build and planning for serviceability.
    Senior Member MPTech's Avatar
    St. Louis, MO
    Removing the body is not hard if you assembled it with that in-mind (make sure to install quick-disconnects on the lights), but it is time-consuming.
    My body is currently off while re-installing my fresh 347 build, installing a new firewall, re-routing heater hoses and installing a mechanical throttle linkage, and some changes behind the dash.
    If it's a SBF, it's easier to service it with the body on. If it's a Coyote or similar, depending on the issue, it could be a wash to remove the body, just more work. (for the record, I hate installing the windshield)
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by MPTech View Post
    These are gold for the windshield. https://fortesparts.com/product/fact...ield-brackets/
  8. Thanks Tooth, MPTech thanked for this post
    Likes Lidodrip liked this post
  9. #7
    Prescott, AZ
    Don't we all. Worse yet is replacing it after one cracks, just adds pain in the wallet too.
  10. #8
    If you're doing major engine work, e.g. an overhaul, maybe pulling the body is an option. But (a) it's possible to pull the engine with the body on, and (b) don't underestimate the effort to pull the body. Lights, yes. But also windshield, doors, side pipes, roll bar(s), front and rear quick jacks or bumpers, hood, trunk lid, splash guards, you get the idea. And don't forget possible wear and tear and what is usually a more expensive than you thought paint job. I would never consider pulling the body for routine maintenance. Changing oil, spark plugs, etc. have varying degrees of difficulty depending on the engine. But all still very manageable and not remotely worth removing the body.
  11. #9
    I had to replace my engine block mid build and though it is not a Ford power plant removing it was not an issue with the body on.
    The good news is is I have tons of friends & family that love to wrench on anything which causes us to often get in each other's way.
    What Happened:
    https://youtu.be/IGYtX-3p7xk
    Removal:
    https://youtu.be/Vhbftk4AP4k
    Reinstallation:
    https://youtu.be/-nVDzIjSjh8
    Just be careful and try to not step on your pal's toes when tackling the task.
    Also, watch your pinkies and other squishable body parts.
  12. #10
    Although working alone I can have a body off 2 hours after driving a car into the shop (done it a time or 2 ) I wouldn't do it. Also, it won't go back together nearly as quickly...we're talking 8+ hours for reassembly, adjustment, etc.
    O'Fallon, MO
    Mark, change the windshield, or change an oil pan?
