Trying to determine if I can pull the T56 transmission without pulling the coyote engine in a Daytona coupe
Mark III 347/435 hp TKO 3.55 axle
Gen 3 Daytona Coyote Gen 3 T56 3.73 diff. (In build)
Superlite SLC LS3 480 hp Graziano Transaxle
I've pulled a TKO out of a Coyote Coupe. I wouldn't expect a T56 to be a whole lot different.
Jeff, did you drop the transmission with /or without the bell housing attached to the transmission or did you leave it on the engine. Thanks
