Looking for feedback on my build as I get started
Hi All,
As I am moving through the first few months of my roadster build, I thought I would share my plans and see if there is any feedback from the group.
My background is that I am a software engineer (Aerospace degree originally) and have a pretty good amount of experience with cars but am no expert. I have a 1968 Corvette that I did a complete restomod with a Sniper injected 600hp 496 big block (from Blueprint engines) and a Tremec 5 speed. All suspension, brakes (Wilwood), cooling, wiring, interior, and drive train I modified and did the work myself. I’m super proud of it. Currently I have the suspension, steering, fuel tank and lines, brakes, and cockpit panels done. I am ejoying the heck out of it!
The roadster I am building is going to be for my wife as well. While I have driven my corvette for years, she has never driven a car like this, so I am concerned about it getting away from her even thought she will most likely drive it like an old lady. I will not be racing the car, and to be honest, I drive pretty calmly most of the time in my corvette other than some fun acceleration from time to time. I have learned some things from the Corvette that I want to make sure to implement with the roadster. I will point those out below. For my roadster I am planning a few things that will anger the purists, but I am used to that with my restomod Corvette.
Drive Train
LS3 376ci from Blueprint Engines
4l70e auto transmission from Blueprint Engines with the motor
IRS rear end from FFR
Paddle Shifters (haven’t decided which ones yet)
Wilwood brakes from FFR
Traction Control (RaceTCS seems to have a great system) – this is more of a safety thing of course
Interior
Different high back seats (haven’t decided which ones yet)
Heated seats
Different carpet and door panels (Most likely custom – maybe from Intatrim)
Dakota Digital gauges (I have them in my Corvette and love them)
Carbon dash from FFR
Cup holders in trans tunnel (I miss those on my Corvette)
USB chargers on the dash
A pocket for my phone (It flies all over in the Corvette)
Stereo using a Bluetooth Amp driven from my phone
Push button start
Other
Expanding the trunk for more room
18x9 front and 18x11 back wheels (Not from FFR)
Electronic parking brake (eStopp)
Powder coated footwell and fender wells (etc) for a super clean engine compartment
I think that’s about it. Any thoughts or feedback is welcome. For the stranger items I tried to show why those, but feel free to ask if they don’t make sense.
Just a couple of things....IMO
1: Ditch the stereo. A lot of expense for something you can't hear. Search the forum and you will see a mulitiude of builders that will agree. Bluetooth from your phone to ear buds may work.
2: A 376 cu.in. is a lot of engine in this light of car. If your worried about your wife and safety you may want to rethink that and go with less cu.in.
But having said that, this is your build so build it the way you want!
Sounds like a great build. I agree, ditch the stereo as it's useless.
Love the LS3, it's a great engine. Lots of power, drives great, and fits well. And don't let anyone give you crap about it not being a Ford, the original cars were built by AC Cars in the UK. Nothing Ford about them.
Looks like a fun build, and the BP LS3 is a great package. They told me they're about 6-7 months out for delivery, so you may want to give them a call if you haven't already.
None of these builds are "pure" so the LS3 doesn't make it any less so.
I talked to BluePrint when I was shopping for engines several months back. The LS3 they sold at the time did not use GM heads and did not have 100% compatible parts with GM heads. You might ask a few questions when you talk to them as things do change. I purchased the Chevrolet Performance LS376-480 long block. Several vendors have them in stock now. I will need to swap the oil pan and add in front drive components. Be sure to consult the FFR LS installation documents regard LS engine installation.
Roadster delivered 8/27/23
The only thing I'd suggest is perhaps moving the USB chargers to an under dash panel. That would keep the dash more clean for whatever style you're going for. Plus the under dash panel will make a happy and accessible home for your push button start box.
Oh; start a build thread. You'll find it VERY helpful in the shakedown phase (now how did I wire that fuel pump again?). They're lots of fun for us to read, too!
MK IV Roadster #8631
Sounds like a cool build, I particularly like the idea of adding traction control - I will be interested to hear how that goes.
With regards to the stereo: there are plenty of people who think it is useless, but there are also some of us who are really glad we installed one, including myself. I have no desire to debate the value of installing a stereo, but I am happy to share what I did if you are looking for ideas. I installed a Garmin Fusion marine stereo (https://www.garmin.com/en-US/p/520066) and mounted the control box in the trunk and the small remote keypad on the transmission tunnel. For speakers I used 4" rounds in the footwells (below where the door hinges are) and 6" component speakers on the rear wall. By using component speakers, I was able to discretely place the drivers behind the seats, but more importantly, I was able to mount the tweeters up high and on the outside of the seats, just under the cowling edge. This creates great spatial separation. I did use an amp because I had one available. The sound is surprisingly good, even at speed, and I would absolutely do it again.
Below, you can see the tweeters are just above the outside edge of the seats and the drivers are pretty hidden. You can also see the remote on the transmission tunnel.
Enjoy the build!
SeattleDiver
Sorry, couldn't resist. Don't shoot me
Just a note on the stereo.... I would 100% do it again. You absolutely can hear it, just not when your getting on the throttle. I have a 427 stroker with GasN side pipes and I love my stereo. Something to listen to while you are just cruising down the highway or at a red light. Mine is a bluetooth with four speakers and a small sub box.
Ted
Mike.Bray
Same. He lost me with an automatic tranny and a Chevy engine. I know the LS series is awesome (I've had several Vettes with them), but not for me in a Cobra. I'll happily follow along in the build thread, though...plenty of other bits of the project that are interesting, for sure. All the creative things people come up with is what makes this place so interesting.
Built an early MkIII years ago, sold years ago.
Got Corvettes out of my system, and now back after 18 years to build a MkIV.
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrok Pro Flow 4, TKX, IRS, Wilwood Big Brakes
Here to learn, contribute, and have fun!
Mike.Bray
It did make me laugh. :-)
If I need my 5-speed fix I will jump in my Corvette and ice my knees and ankles later.
I probably should have mentioned that in my life I have broken 27 bones. Most of them in my ankles and ribs and blown both knees out.
But thats a topic for over beer. :-)
I use my blue tooth stereo while cruising and while parked at cars & coffee after I've made the rounds and am just sitting in a chair next to the car.
Two speakers behind the seats, and two forward in speaker boxes below the door hinges with an amp mounted under the dash below the glovebox.
OB6
Yeah I talked to them about 2 1/2 weeks ago and found out about the lead time, so I placed my order then and there.
My 496 was ready in just two months. Looks like I will eventually be blocked for a bit later in the spring, but that will give me time to tear the dash apart on my Corvette to replace the heater core that went out.
SeattleDiver
That's not really much of an excuse Evel Knievel hahaha
