Thread: Which aftermarket seat sliders have traveling handles?
    May 2023
    Salisbury, NC
    I’m looking at some double lock sliders with a common bar but don’t want the seat to eat my hand when I pull forward. I know several of you have used several brands and wonder if anyone can tell me if theirs has the adjuster travel with the seat?
    MkIV Complete - Dart 427/TKX/Sniper II/IRS from Forte
    As far as I know they all do. Otherwise, once it was forward you couldn't reach the handle. I did have one car come through my shop that had them mounted upside down. did exactly what you describe.
    Sep 2022
    Huntington, IN
    For my '33 Hot Rod, I used these from Summit. I had to modify the cross wire that attaches the tract brackets but that was pretty simple. https://www.summitracing.com/parts/SUM-G1153
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    I'm pretty sure if you just flip over the slider (upside down), the handle will travel with seat. Typically, the handle is attached to the bottom of the slider, but if you flip it, it'll be attached to the seat.
    Ted
    May 2023
    Salisbury, NC
    Sweet thanks for the quick responses!
    Aug 2012
    Grand Rapids, MI
    I have a pair of the Sparco, double lock sliders. Summit has these for about $80/set although prices have probably changed.
    The slides are independent, and the adjustment bar can be changed to accommodate various widths. These are quite low at about .6" thick.
    Jim
    Folsom, CA
    keep in mind if you want to track the car, you'll want dual locking rails, I used this allstar setup (or very similar) from speedline
    Allstar ALL98100 Seat Mounting Track Assembly Kit with Adjustment Handle, Universal ~$50
    https://cobradreams.com/2023/04/04/m...t-heater-pads/
    Todd
    Senior Member MisterAdam's Avatar
    Brentwood NH
    How much do these kits raise the seat? I am 6 ft tall and am concerned with the top of the windshield frame obstructing my view
    About an inch.
