I installed a 255 Walbro pump into the Pro-M hanger, but it can slide up and down fairly easily. Wondering if I need a sleeve to tighten it up to prevent movement and vibration?
But maybe this isn't a problem.
Terry
Hi Terry,
Is the Po-M hanger the one with the optimized fuel return line (so it doesn't "froth" as much)? If so, I used this and I purchased a similar pump from them also. It came with a rubberized sleeve that seemed to create a snug fit. I really don't know the material composition, but I suspect any fuel-proof material would be good enough. Maybe there is a distinction with ethanol fuels, though
Craig C
Craig, yes that's the hanger I have. I think I need to get a sleeve, but maybe someone will tell me otherwise. Walbro makes one for this purpose.
Terry
Same that I found. I just slightly bent the carriage to hold it snug then re-tightened. Curious to hear any others.
Coupe Kit Delivered 11/10/23
Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
Once you snap the filter sock onto the inlet of the pump it won't be able to slide up and down any more.
I drove down to Summit Racing because I needed a couple things, so I picked up the Walbro 122-332 sleeve for a whopping $2. I'm confident you're supposed to use one of these, now that I see it installed and feel how solid it is. I removed the four screws to take it apart and insert the pump... likely no way to do it otherwise with the added diameter.
Terry
Yep, that's what mine looks like, and I recall that's how I installed it Pretty cool that you can drive to Summit, although they're good with deliveries, too...
Craig C
