Thread: Rear Brake Flex Line Bracket Location Option
    Senior Member Mat1asBEV&ICE's Avatar
    May 2023
    Boston
    Hi. I'm trying to decide which of the following two locations will work best for the flex brake line bracket. Important to note, based on my e-brake cable routing is one option better than the other (thinking about interference)? I am running the stock e-brake cables with 2015 Mustang GT 13" rotor and calipers. Thank you!
    Option 1, others builders have done this, but I haven't seen it done with e-brake cable in my location.
    Option 2, as described in the manual.
    Delivery October 2023, #10847, Gen 3, IRS
    Norton, MA USA earth
    I put it on the angled tube that the upper control arm is attached to.
    Senior Member DW66's Avatar
    Jan 2020
    Plymouth Mass
    This is probably where Mike puts his. I might have used a few of his methodsbrake line.jpg
    MK4 Complete kit FFR9939. Gen 1 Coyote, Tremec 3650, IRS 3.31 ratio, Breeze radiator stuff, Breeze cubby and battery mount, North Race Cars heat and A/C, RT drop trunk kit, Replica Parts radiator aluminum and brake booster spacer, FFR soft top.
    May 2023
    Boston
    Thank you, guys. I was wondering which position would be better when planning ahead for the hard lines.
    Dave, would you happen to have a photo of the hard line routing near the flex line bracket? Curious what that looks like. Also, I am getting the RT/Mountain Metalworks drop tank if that makes a difference.
    Jan 2020
    Plymouth Mass
    Senior Member BRRT's Avatar
    Sep 2020
    Rear Brake Lines
    A few pics. I used flex lines from Pegasus Racing
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    May 2023
    Boston
    Muchas gracias.
