Results 1 to 4 of 4
Thread: Steering arm to spindle mounting bolts
    Dec 2020
    Washington, MO.
    The manual shows using button head bolts to mount the steering arm, but none were shipped. I was shipped standard 1/2" bolts along with some 1/2" 12 Point bolts with the same threads.
    The manual doesn't specify which parts to use, so I am asking for some direction / help before I put the spindles on & torque them down.
    Norton, MA USA earth
    They no longer use the button head. They are standard bolts with a flange lock nut. the 12-point bolts are to mount the caliper.
  3. Thanks kcwitt thanked for this post
    Kevin, be sure you get the arms on the correct side.
    May 2023
    Frisco, TX
    On behalf of all of us who screwed this part up—I can’t stress enough how important this is to get right the first time!
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
