Thread: Speaking of guages - oil temp
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    The thread on the useless clock reminded me. I have an oil temp gauge that used to be hooked to a sensor in my oil pan. Now after the engine swap I no longer have a sensor anywhere for my oil temp. What's an easy way to resolve this? I know they (oil temp gauges) are rarely accurate and to many a mechanic the bane of annoying questions from old fiddlefarts like me. I would like some reading on the gauge though even if I mostly ignore it. :-)
    I should note there is not a bung in the oil pan for one. It's a brand new Ford Racing Boss 347.
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
    Jul 2022
    DFW Texas
    I used an oil filter sandwich to gain access to additional ports.
    https://a.co/d/ahPNSyQ
    Also I 'think' I have seen drain plugs drilled and threaded for a sender.
    You want it in the sump or in the flow such as via a sandwich like JJK mentioned. Some guys mistakenly put them in a “T” with the oil pressure sender and then find that the gauge never moves because that oil is deadheaded.
    Aug 2020
    Hollis, NH
    Cool! That looks easy with the sandwich. Thanks!
    Sep 2015
    Hamersville, Ohio
    Mmm! Did someone say sandwich?
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
