Results 1 to 4 of 4
Thread: Gen 3 Coyote Manual Harness Missing and Required
    Dec 2020
    Hi,
    I have just got around to wiring up a Gen 3 in my Daytona coupe, and have just found out that I am missing the manual harness. Looks like the harness is only used for connecting to the o2 sensors
    I have reached out to Ford performance but they said it is only available as part of the full control pack.
    Engine and control pack were supplied by Factory Five about 2 years ago. I reached out to them via email earlier in the week but haven't had a reply as of yet.
    Anyone got any suggestions on where I could possibly source as a stand alone, if Factory Five are unable to help? The part number according to the Factory Five installation manual is CM-14A006-MTRANS .
    Dan
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    Maybe a little more clarity is needed on what you don't have. Do you have the control pack with the computer, PCB fuse box etc? All of which is tied together. The pack comes with O2 sensors and depending on where you got it they sometimes include extenders. Are you missing the engine harness?
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Covid
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55 [/B]
    Dec 2020
    Hi,
    I received the control pack that included the accelerator pedal, intake boxes with MAF sensor, the PCM, the o2 sensors and the control pack main harness with the fuse box / OBD etc. I have the engine harness.
    What I am missing is the smaller harness that connects from the PCM to the o2 sensors. Images below:
    A little tough finding a shortage two years after the fact. Going to be hard for Factory Five since they probably would have to break up a control pack to provide only that harness plus their policy for reporting shortages. Although they typically are pretty relaxed about the actual deadline. Seems Ford Performance would be your best bet. Buy a whole Control Pack? Nice. What about one of the performance shops that deal with Coyote swaps? Like https://pbhperformance.com/ They might even be able to supply one that doesn't need extensions.
