Results 1 to 4 of 4
Thread: Location of MKIII rear frame cross member vs. MKIV
    Senior Member Crawleyscobra's Avatar
    Does anyone know if the rear frame cross member on a MKIII is in the same position as a MKIV?
    FFR6682 - received 7/30/08 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475HP/500lbs), TKO600, Power steering, Power Brakes, Hydraulic Clutch, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Mustang Cobra rotors w/calipers, NITTO NT05s - 255/40R17-Front, 315/35R17-rear,3.55 IRS.
    Visit my Blog: http://crawleyscobra.wordpress.com
    If your car has the bolt in trans mount then yes. Pretty sure they are in the same spot.
    Mike,
    Yes mine has the bolt in trans mount.
    Thanks that answered my question.
    Dec 2020
    We'll check this new MKIII project soon and it may need to repair the rust in the cross member. There's a good amount of rust but hope it's not that bad. Got to finish mounting the new tires and dually wheels on the F250 before we can clear a spot for the MKIII in the garage.
