Just roughed-in my Mountain Metalworks drop trunk this past weekend. Quality product!
Got a little more time in today. I played with the Breeze gas pedal and figured out how it will integrate with the Forte throttle linkage. Removed the throttle cable linkage from the pedal and drilled out the hole to accomodate the bar end from the Forte kit. I then bolted it in, guessing where its going to go. I wonder how easy this will be to change when it needs to be adjusted to the Forte linkage once the engine is in and the footbox is closed up. I guess we will see...
I also began drilling and riveting the passenger footbox aluminum. No real issues here yet with only 2 pieces installed. The only question mark was with the center tunnel piece. I assumed it should be centered so there is a little bit of room on either side between the flange and the transmission tunnel.
Build Thread: https://thefactoryfiveforum.com/show...-s-Mk-IV-Build
Order Placed 12/18/20. Kit ready 4/3/21, picked up 4/6/21
Mk IV complete kit IRS Forte Boss 427 TKX
Niiiice... I heard back from them and am ordering the drop trunk and turn signal kit. He said there was a little bit of a wait for that one. He's still getting caught up.
Hi Ethan,
Can you describe a little more how the RT Accel Pedal integrates with the Forte' rod setup? I have the latter and am waiting on the former...
I can imagine that one of the linkage rods actually installs inside the footbox (just between the inner wall and the inner 3/4" square frame tube), but do you have more pictures that you can share? Also, does the 2nd "main" rod support get bolted to the firewall inside the footbox or outside?
Craig C
I just purchased a straight pedal bar from MMW, the curve on the original RT pedal had my foot very close to the inside wall before any carpet or heat shield.
Hey Craig,
Do you have the instructions for Forte's linkage? If not, they can be found here: https://fortesparts.com/technical-do...-instructions/
There are some pictures of how the whole thing bolts together, and he even used the RT pedal in the pictures.
I haven't gotten very far with this, and I don't yet have any of the Forte linkage actually installed, but I have it figured out in my mind. My firewall is only clecoed in at this point, so I haven't installed the shaft supports, and my engine isn't in yet, so you can't tell where the throttle body end of the rod goes.
Basically, the rotating shaft goes parallel to the firewall, and both its supports bolt to the firewall outside of the footbox, in the engine compartment. The big washers lend them support. You'll cut a hole in the footbox wall for the shaft to go through into the footbox. The two rods are reverse threaded on one end, for the ball joints to screw into. Both rods get cot to the appropriate length, and then once you have cut them, you tap threads into the other end for the regular thread ball joints to go in. One rod goes straight back from the throttle body towards the rotating shaft, and the other goes inside the footbox from the shaft to the gas pedal. The adjustability comes from the length of the rods and the angle of the connecting arms on the shaft.
The Breeze/RT gas pedal has two different linkages to connect to different throttle cables, but you won't use either. You'll bolt one of the Forte rod end ball joints to it instead. The hole isn't big enough, so I openned it up to 1/4" to accomodate the ball joint. I used the reverse threaded one so I can attach the rod and then trim the other end as needed before threading it.
As I said, I don't have most of it installed,but here are a couple pictures of the gas pedal. I'm not sure where on the frame tube it will end up, and won't for a while yet.
IT all does look pretty tight in there. I am prepared to do some bending of the pedal if needed so that everything (including my foot) fits.
I had to adjust the RT gas pedal a little. The dog leg bends easily in a vice. Regarding your Forte throttle linkage, you should have all of that adjusted before you button up the footbox. The rod ends are adjustable, so very easy to do.
Thanks for that. Good to know. I was concerned about that. I'd prefer to be able to sit in the seat and adjust the pedal for ideal placement. I'll also need to measure the full travel of the throttle body to make sure I'm getting the right range of motion at the pedal. Maybe I'm overthinking it?
You are definitely thinking about it the right way. You want the Forte linkage to allow for full extension of the throttle body without overextension. Might want to think about a pedal stop once you get it configured correctly. And don't forget to roll pin the lever arms to the SS rod to avoid slippage.
Thanks for the tips!
Hi Ethan,
Thanks for the extra pictures and link
I've been the Forte' website many times, but never visited the Tech Support page. I ended up calling them last Friday and they told me it was right there. I had a good mental image of the overall arrangement, but was short on some details until I saw the pictures.
I'm also trying to think ahead (like you) and the challenging thing about this install is that the panels really need to be located/drilled after the engine is installed or very careful measurements are taken...or iterations to that effect.
I've heard other builders say that you build the car several times before it is done -- I believe it now! Thanks again for the pictures
Craig C
Still working at a snail's pace, but working nonetheless. I picked up where I left off with the passenger side footbox. I got most of the way through it. Everything seemed to fit together reasonably well.
I need to fabricate a small filler piece to close up the gap around the Round frame tube. I plan to use aluminum tape to seal everything up, and then insulate the insides afterwards.
I started test fitting the passenger side cockpit floor piece, and that project looks like a bear. It was really difficult to get in to place at all, especially with the parking brake handle in place. The handle will certainly have to come out for final installation of the floor, and it looks like I might have to do some trimming of the floor aluminum at the far outer edge at the back side. A lot of scraping and bending and force to get it to fit into place. I think I also decided to wait to install the floor pieces until at least the brake lines and fuel lines are run, and maybe even parts of the wiring harness as well. I can't tell if they'll be in the way, so it seems to me harmless to wait for now.
Looking ahead to what's next, it looks like the fuel system will be next. I seem to remember that people find it much easier to get longer tank strap bolts. Anyone know what size works best? I am also doing the klener mod and a drop trunk. Any advice on what order to do all of these things in? Is it Kleiner then fuel tank, then drop trunk?
Looking good Ethan
I use a small flat blade screwdriver to lever the Passenger-side cockpit floor past the standard handbrake mounting tab...at least I used to. Cut mine off this past weekend (but only after I really knew I had a workable alternative)
My floor panels did not fit well at the rear, either. I ended up making some shims. No harm in making it fit the best you can.
As far as order-of-execution goes. I tend to mock-up parts before "locking it down". To each their own...
In fact, the only panels that I've riveted are the "F" panels...and I'm considering removing them anyway
Craig C
Thanks Craig. I'm trying to balance my need to check off boxes in my head with keeping my options open and accessible! I am erring on the side of options...
I know, I'm all over the place. Some days I don't have time in the workshop but I can squeeze in some research and planning between other tasks. I had some thoughts on the brakes, as I'll be doing the hard lines soon.
1. A lot of builders seem to prefer pressure bleeding the brakes. Are the hand pump ones less likely to do the job than the ones that use a air compressor? Does anyone know if the Wilwood billet remote fluid reservoirs accept the standard 45mm adapters? I measured it with a caliper and it was just over 45 mm.
2. Most people say to bench bleed the MCs. Having already installed them, I'd prefer not to take them off to do it. I understand they need to be level to be properly bled. Is there any reason not to just jack up the front of the car to make them level and just bench bleed them in place?
Any input is welcome and appreciated!!
Before you start buying tools to bleed the brakes, try gravity bleeding.
I have the Wilwood master cylinders and calipers. I filled the reservoirs and opened the bleeder to the passenger rear caliper. After a few minutes it was dripping. The remaining 3 bleed the same. I topped the reservoir off for each caliper. I did pump bleed them all and found a minute amount of air in a couple.
IMO about the only thing that will interfere with this method is the master cylinders not being at full release.
Good luck,
X2 on Railroad's experience. It was a no stress event for me too.
Gen1 Coyote / TKO600 / IRS
I installed the cockpit floors before the brake/fuel lines were installed. not a huge deal to lay on my side to install these. you need to get under the car to secure the lines where the seats go anyway due to the cockpit floor.
for the trunk, do the Kleiner mod first, then install the drop trunk (if using the RT drop trunk kit) and then the fuel tank. With the tank in place, you won't be able to install the drop trunk or the lower PS bolt for the Kleiner mod. I'd get everything plumbed up first before installing the lower trunk aluminum panel. you can always cleco the drop trunk in place while you're working. I'd consider running the rear wiring harness and hook things up to where they belong before putting the lower trumk aluminum in .
I did a pressure bleed for the brakes. use a hand/bike pump to around 5-10psi. too much pressure and you might blow out your master cylinder diaphragms. I didn't bench bleed the MCs and it worked just fine.
These are pure gold when bleeding brakes. https://www.amazon.com/dp/B000CMDP44...t_details&th=1
I used to use a small bottle with a hose running into it but I'm so clumsy I would always knock it over spilling brake fluid everywhere.
Awesome stuff guys, thanks. That's exactly what I was looking for!
More random thoughts as I peruse other build threads. I see a lot of people grease the control arm bushings before installation, both in the zerk fitting and on the side. I didn't get the memo. Is it worth taking everything apart to accomplish this or do I just hit all the zerks and call it good?
I bit the bullet and dedided to take off and grease all of the control arms. I also decided to check the adjustment settings of all four shocks while I was at it. It never occurred to me that they might not come in the correct setting. The rears were both good, but both fronts were messed up. Neither of them stops when you rotate the shaft trying to adjust them, and one of them leaks pretty bad when you press the adjustment button. I have reached out to factory five to see what they say. I also got one side of the rear suspension taken apart, greased and put back together. There was some straining, banging, and quite a bit of blood, but I got it done. The other 3 corners should go quicker, I think.
I'd also like to echo CV2065's plug for the locknlube zerk coupler. Fantastic. I was also very happy about my milwaukee cordless electric grease gun and the Lucas oil Green heavy duty grease.
Well, I managed to finish up that project. A bit of a pain to take everything apart and coax the control arms back into place, and also to clean up all the grease, but I'm glad its done. While I was working on the front, I noticed the condition of the front upper ball joint dust boots. Holy cow. The manual says that they will deform and look wierd until there is weight on the suspension, but I don't think this is what was meant:
The other one wasn't as bad, but still has a crack and hole in it. That stinks.
I sourced all of the hardware for the kleiner mod, so I'll be sticking those couplers in soon. Then I think I'll run the brake lines and mount the reservoirs. I have the Forte/Wilwood triple reservoir. It seems most people mount these to the frame tube in front of the driver footbox. Any clearance issues I should be aware of?
Another day of one step forward two steps back. I decided to address the upper ball joint dust boots. Way back when, I had bought the energy suspension dust boots (5.13102G) but they didn't really seem to fit to me, so I didn't use them. Now that the FFR ones have disintegrated, I am going to try the energy ones again. My progress on the car has been so slow that the front suspension has been sitting up in the air for over 2 years. I don't know if that contributed to the deterioration of the dust boots, but it certainly seems to have seized up the front suspension joints. It took an hour of prying and banging to get just one side apart. I tried some penetrating oil and some heat, but at the end of the day, it took a hammer, and not a dead blow one, to get it all apart. Am I doing something wrong here? Should I be putting anti-seize on these?
I dug out the energy dust boots, and wasn't too sure which of the two styles was best. This one, the longer one, seemed to fit better, but I see others have used the shorter, flatter one up here. I guess I'll try that one again.
In other news, I heard back from factory five about my defective shocks. They say they'll replace the leaking one, but not the other one. Every communication cycle seems to take at least 24 hours, so I'm not sure where I stand yet, but I'm not going to be thrilled if I have to pay to replace the other shock. It's definitely not working right.
Yeah, that looks a little better with the shorter, flatter dust boot. This picture has the suspension jacked up with a floor jack, so hopefully when it droops, it wont deform the boot too bad. I am sort of waiting to torque it all up again until I figure out if I'm going to use any anti-seize on the ball joint shafts.
I also decided to retro-actively hit the rust prone parts of my axle shafts with some POR 15, so I started the prep for that. And while I was at it, I decided to hit the ABS sensor holes in the rear knuckles with silicone. What a mess. Probably a mistake to do that now, but at least its done. If you do this after the fact, be very sparing with the silicone. I didn't realize those holes went through to the bottom and got silicone everywhere. Pain in the neck to clean up with everything in place...
Well, I think learning has occurred. A frustrating couple of hours in the workshop, to be sure. On the plus side, I finished prepping for POR 15 of the axles, so I'll be able to paint tomorrow once things are dry. That didn't take long. I decided to try to reassemble the front suspension with the energy dust boot, and found that all of my hammering had destroyed the threads on that ball joint, and I couldn't get the castle nut on. So after all of that, it seems I will need at least one new ball joint. Probably not worth trying to put new threads on that thing...
I guess I'll be deciding whether to upgrade to the Howe ball joints that others have used, or to just replace this one. Do I want to disassemble both upper control arms, or just one?
Either way, while trying to disassemble the other side and finding the same stuck ball joint, I learned that its better to spend the time and money on the right tool than to create extra problems by being impatient. An irritating and expensive lesson to be sure, but I'll be finding myself a ball joint separator along with my replacement parts.
And Factory Five isn't going to help with both of my bad shocks, just the leaking one. Not cool. $165 to replace a part that was bad from the get go. A very expensive day in the shop all put together.
The Howes ball joints are $100 apeice plus dust boots. I think I'll find another mevotech....
At the rate I am taking one step forward and two steps back, I will have the whole kit disassembled pretty soon! I got a ball joint separator, and even though its a little tough to get the fork in between the spindle and the boot, once its in, the ball joint is out in 30 seconds.
I was also able to get the damaged ball joint out of the driver's side, and after some scuffing with a wire brush my new Moog K772 ball joint threaded right in to the upper control arm. That was as far as I could progress.
None of the dust boots work on either of the ball joints. Here is the Energy Suspension dust boot on the Mevotech ball joint:
It just won't seat all the way, and the gap gets worse when you move the suspension up and down. The boot is just too small. It looks the same on the Moog Ball joint.
The dust boot that came with the Moog ball joint is even worse. It just collapses on itself:
I got so frustrated with the situation, I just had to quit for the day. I don't know what the solution is. The mevotech boots fit OK, but both of them had cracked just sitting in my garage....
I could really use some advice here. Has anyone had these issues? Is spending over $200 on the Howe ball joints and boots really the only answer?
Energy Suspension 5.13102G dust boots are the right parts. The small/shorter ones are used for the upper ball joints. When drooped, they may look like they don't fit. But at ride height should slide into place. This is from one of my builds. You can see it in the background. Sorry, best pic I could find. In this case, Howe ball joints under the covers. But shouldn't change how they fit with Moog or Mevotech. Notw also Energy Suspenion boots on the tie rods. Those are Energy Suspension 9.13101G dust boots. Also highly recommended.
Thanks as always Paul for your knowledge, experience and willingness to help. After sleeping on it I had pretty much decided to use the energy ones and then just keep an eye on them as I put the drivetrain in and put it down on the wheels. Your 20th Anniversary build is like a build manual for me.
Sometimes you just have to clear your head, I guess. I'm still a little leery of how those dust boots fit, but I put it all back together. They look OK in the middle of the front suspension's movement, but not very good at either full droop or full up. I don't currently have the shocks in, so those will obviously prevent the suspension from reaching either extreme, as will the weight of the car, so at this point, I'm just going to hope that's good enough and keep an eye on them and keep them greased. Here's what they look like at full up and full down.
Other side:
I also put a second coat of POR15 on the axles and installed the coupler nuts for the kleiner mod. Much more satisfying to check a couple of boxes than continue to wrestle with dust boots. As others have found, I was unable to get a wrench on the ball joint castle nuts to properly torque them. They seem to be between 13/16" and 7/8". I couldn't get the 13/16 crows foot on and the 7/8 would slip off with any torque. So I just did it by feel. Very scientific.
Factory Five also came through and is sending me two new shocks. That is the customer service you hear about and hope for.
Been a little bit but I got some time in this weekend. I managed to fabricate a hydraulic reservoir bracket. I started with a 12” square plate of 1/8” aluminum and cut it down using a cut off wheel and smoothed it off with the bench grinder. I tried to match the slight curve of the frame rail. I mounted it as close to the footbox as I thought was practical. These wilwood reservoirs from Forte can be moved up and down in the bracket so I can mount them such that the caps stay flush with the frame rail for body mounting purposes.
I also started working on the brake lines. I went back and forth quite a bit about finding some shorter lengths or even getting a flaring tool and making custom lengths like others have, but in the end decided to try to give it a go with what I have. I love adding tools to the arsenal but you can’t do it every time and I figured it was best to reduce the risk of leaking lines due to bad flares. I do tend to overthink things a little bit so I just went for it. I did buy a cheap tubing bender for nice smooth bends where there is room to get the tool on the line and it has helped.
I started with pieces of wire cut to the length of the brake lines to make templates, using handy items like wine bottles to create loops. I got a couple lengths in before running out of time. I started from the footbox and used the edwardb routing. Pretty happy so far. I haven’t had to throw any out yet.
Found a couple of hours today. After finally getting 2 replacement front shocks from FFR, I reassembled them and then reinstalled them and torqued the bolts. Feels good to have that back together. I'm still not thrilled with those ball joint dust boots, but I can't mess with it any more and others seem to be happy with the same setup.
I also messed with the castle nuts and cotter pins on those ball joints, making sure everything looked OK. The replacent ball joints had the hole for the cotter pin in a different place, so on one side only one washer was required.
I then finished bending the front brake lines. The line crossing to the right side didn't come out quite as good, but it's a pretty complicated shape. Overall, I'm happy, and it'll look good once I clamp it into place. I've seen others with similarly shaped lines. Any chance any of those loops will interfere with engine installation?
Those Energy Suspension boots you installed...I replaced my craptacular kit-supplied blue ones with the same Energy Suspension kit, but when I installed them, I erroneously put the wrong ones on, and the incorrect ones set just like yours do. I swapped them for the other two in the package, and they fit much better. You sure you didn't put the wrong ones on?
Thanks for that. I have agonized quite a bit over this, having tried 4 different dust boots with none really looking perfect. See posts 144-149 above. I did try the longer ones and they got too squished. Paul (edwardb) confirmed that he used these same ones, so that’s as good as gospel for me. In the middle of the suspension travel, they seem ok. It’s only at the extremes where they don’t look good. I guess if they’re greased and spend 99.9% of their life away from those extremes, it’s probably ok. I do wish they fit more securely. The blue ones that came with the kit seemed ok but didn’t even last 2 years in my climate controlled garage without cracking.
Happy independence day, everyone! I was all scheduled to work today, and I sent the family to the lake for the holiday, and they cancelled my work day. I still have to work tomorrow, so what was I to do with the day? Easy answer. All by myself with time to kill, I got a few hours in on the build today. Having spent some time thinking about the routing of the rear brake lines, I knew I was going the edwardb route and running the line through the footbox and out the bottom to join the frame rail. I had to drill a big enough hole to get the brake line nut through it, so it seemed like it was time to put in the driver's side footbox floor. I mocked the whole footbox up to see how things were going to fit, and saw that things looked pretty good, even with the FF Metals forward firewall changing the fit of some of the pieces. I measured three times before drilling, and got the floor all riveted in.
I then played with some 1/2" grommets I got, making holes in them with some leather punch drill bits I got on amazon:
I then slit the grommets to get them on the brake lines. It was a little tough to drill the hole in the gas pedal bracket, but I managed to get it done. I then started mocking up the brake line with some wire. It was going to be impossible to get the bent line through, so I jacked the car up as high as I could, and made the bends near the top of the line by the master cylinder. I then fed the line through the hole I made in the gas pedal bracket, then through the footbox, and out the bottom using the hole I had drilled. With the car jacked up, there was enough clearance to get the line through and bend it slightly as it hit the floor. Once it was far enough through, I put a real bend on the line to send it down the frame rail. Not the most precise and not the prettiest, but it got the job done. It was dinner time, so I quit for the day. I'll plan to come back and refine some of the bends and clamp it to the vertical 3/4" frame rail inside the pedal box, and to the frame rail under the car.
Finished running the brake lines today. Mostly went fine. Once I have checked for leaks and bled, I'll mount the lines to the frame.
