0
0
GPS SPeedo set up & wiring questions
1st - I assume I just disconnect the green signal wire to the speedo and replace with the Violet signal wire from the GPS interface, correct?
2nd - Where did you guys mount the GPS antenna?
any issues I should be aware of?
