Results 1 to 15 of 15
Thread: Need your wiring help - PLEASE
    Sep 2022
    Huntington, IN
    I have a few wires that are not connected to anything and the ends were taped off but they have terminal ends. Hopefully you can help
    Pink - Hazard Flasher
    Blue 2 wire -1 says Right Frt turn the other has no writing
    Blue single wire - Right Frt Turn
    Green 2 wire - 1 says LFT FRT TURN
    Green single wire - LFT FRT TURN
    Grey - TURN FLASHER FD
    Brown with a plastic plug end - Gauge Feed
    2 red wires - Speed-Clock MEM
    Brown - High beam Ind LT
    Green - LFT DAS IND LT
    Blue - RT DASH IND LT
    Are you asking where those wires go? Do you have the instructions that were in the harness box? The hazard wires go to the DPST 6-pin (on-on) switch. The turn signal wires go to the on-off-on switch, the headlight wire goes to the on-off toggle switch. If you have a GPS speed, run a red speedo-clock wire to the correct wire on the gauge. The dash feed goes to the main power wire for your gauges and to the voltage gauge. The left & right indicator wires go to whatever lights you use in the dash for your turn signals.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member of the The Gateway Cobra Club
    Sep 2022
    Huntington, IN
    no, I do not have the instructions that were in the harness box.. that would be too easy
    Quote Originally Posted by Just 1 More View Post
    You can download it from here: https://www.factoryfive.com/wp-conte...ness-rev-W.pdf
    Legal: 1/30/2020
    Sep 2022
    Huntington, IN
    You said the "The turn signal wires go to the on-off-on switch" but my turn signals are in the steering column
    I see you are building the 33, so whatever you are using from the column connector can be ignored in the loose wires. I had the opposite when building the roadster and didn't need the column connector.
    Legal: 1/30/2020
  7. Likes Just 1 More liked this post
    Sep 2022
    Huntington, IN
    Would be great if they had one SPECIFICLY for the Hot Rod that says "you don't use these wires" for wiring dummies like me
    Oct 2022
    Cutting back and taping off all the wires mentioned in this post are covered in the wiring section of the Hot Rod Assembly manual. The Ron Francis manual is almost exclusively for the roadster.
  10. #9
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Dgc333 View Post
    Well dang, I missed it when scanning through.
  11. #10
    Sep 2022
    Huntington, IN
    Just so you guys know, I bought this kit partially assembled and have blown everything apart and basically started over redoing almost everything. The wiring was already done so i'm backtracking what has been done to make sure it was done right.
  12. #11
    Placitas, NM
    So did your car come with the iDidit steering column?
    Don’t cut those wires too short until you have everything connected and tested, just in case.
  13. #12
    Sep 2022
    Huntington, IN
    I assume it's an IDIDT column. How would I know?
    I didn't cut them, I capped them and leaving them as part of the harness
  14. #13
    Placitas, NM
    Does it look like this? They came unpainted and in chrome.
  15. #14
    Sep 2022
    Huntington, IN
    Yes it does
  16. #15
    Jul 2020
    Spencer, MA
    Follow the wiring directions in the Hot Rod assembly manual. There are a couple of cuts to be made for the lights so you don't backfeed them when using the Ididit column. These probably have already been done. Download what Papa suggested and use the diagrams as reference. They show Hot Rod and roadster wiring. The diagrams and gauge directions are useful in wiring the gauges.
