Hey Fellow Dark Sider,
I'm assuming that you are building a 33-HR or Hot Rod Truck and if you are then you will need a
short water pump not the more common longer versions. (Standard & Reverse Rotation)
As for the stall of the converter, understand that every combination is different. The weight of our cars, in our case the lack of weight, comes heavily in to play along with the engines operation range and transmission stall speed requirements. With that said, a convertor that flashes/stalls between 2,200 and 2,400 RPM would work fine with a reasonably cammed 383 because that engine makes a lot more torque than the beloved 350 SBC. That extra .27" of stroke (
3.48" versus 3.75") makes a huge difference so while the 350 SBC is a nice Mouse Motor, the 383 is more like having a Mighty Mouse Motor.
If you are going with a Blueprint 383, with a 700R4, then I'd suggest hitting
The Easy Button and simply ordering a complete kit similar to one in the link below, but remember the 33 HR and Hot Rod Truck need a short water pump:
https://blueprintengines.com/collect...9e1561f9&_ss=c
As for me, I am probably the
Biggest Mighty Mouse Fan on the forum and here is why:
https://www.factoryfive.com/whats-ne...-mk4-roadster/
Good Luck & Welcome Fellow Dark Sider!
PS: Hope This Helps!
