In the dumb question category I am sure ...
Where does one properly route a PVC valve on a SBF valve cover to an eight-stack induction system?
Thx!
Thx!
If it was mine I wouldn't run a PCV. I'd put breathers in the valve covers. Or a catch can on the firewall and plumb it to fittings on the valve covers.
I run breathers with my carb motor. Has worked well.
Jim
PCV on one cover is connected to the manifold vacuum of the carb under the throttle blades. The other valve cover has either an air filter looking breather or a fitting connected to the air cleaner for fresh air. I put an oil catch can between my PCV and the carb to avoid too much oil gumming up my valves.
it's going to depend on what state you live in. In the beautiful state of Commiefornia, I was required to build a box to encapsulate all eight stacks, and the cap from the valve cover that did not go through the PCV had to go to the box. The other valve cover with the PCV I had to put a non-breathing cap. The hose from the PCV goes to an air/oil separator, and then continues to a port in the intake manifold. The box that I spent hundreds of dollars on now rests on a shelf in my shop. I now run the hose from the non PCV cap to the trumpet on, I believe, the number eight stack. Haven't seen an issue yet, but only a few hundred miles on it since completion.
20220209_164800 by Rick Paul, on Flickr
20220209_164750 by Rick Paul, on Flickr
20210615_100941 by Rick Paul, on Flickr
Rick
It’s a trick with an 8 stack. You have to run the PCV in the valve cover to a vacuum port in the intake manifold. Unless you purchased one specifically for this purpose or are willing to tap you own intake manifold, you probably don’t have this port. Some have made a complex spider of tubes from each carb to a common vacuum outlet. There are pics on the forum if you search it. The other valve cover needs to feed filtered air from above the intake. In CA this requires a cover over all 8 intakes as seen in EZ$’s pics.
Are you running carbs or FI? In CA? Let’s just say it’s hard to do. Most would say don’t if you don’t have to. I’m in CA and got my SB100 smog exemption with a PCV system on a plain ol’ Holley 4 barrel. I got my plates and BAR sticker. Unless I’m reading the law incorrectly, I can put whatever intake I want on it now.
Drew
No, you're reading the law correctly. There are no further inspections on SB100 cars after they are titled and registered.
No you weren't. You were required to understand the law. You could have put a regular intake and carb on for registration and then put your stack intake on afterwards.
JohnK is correct here. In California, you can do whatever you want after the BAR (Bureau of Automotive Repair) inspection is passed with your sticker. Take that box off and show your off beautiful stacks!!! The stacks are tricky and I have a friend contemplating what to do, but find a used intake and carb to pass and change it all out.
Ted
Thanks all for the responses.
I was asking as I have a breather / oil fill cap on one valve cover, and a poppet valve (I believe) on the other cover, from which I have just run a hose to the back firewall. The stock Blueprint Engines setup.
What I find is that I have of oil vapor exiting the breather, with over time puts a nice gloss on my valve cover and results in a drip below the bell housing. I am guessing that manifold vacuum, i.e.: connecting that hose to the induction system would get things flowing the right way. The vent allows air in, the valve allows oily air out, and this gets processed on the wrong side of piston rings.
I don't have any manifold ports available on the Inglese EFI 8-stack. Looks like I may just let the beast mark it's spot ...
You could just hook both valve covers to an oil catch can with a breather. It will collect all that oil being spilled on your covers. You just empty the catch can every so often.
Like this:
.boB "Iron Man"
www.RacingTheExocet.com
If you only pull from one or intake port, you will get a weak and pulsating signal. Drawing from all 8 gives you a much stronger and consistent signal.
Also remember that in 1965, the crank case was vented to ambient air.
.boB "Iron Man"
This is a great thread for me as I'm running the same setup as Bob and have seen all sorts of setups with the valve covers. Is the reasoning for all this routing from the valve cover vents an emissions thing? Engine longevity thing? If it's just the fact that some moisture and oil comes out of the vents does the vented catch can route to both valve covers? Presently I just have vented covers.
