Thanks Thanks:  2
Results 1 to 5 of 5
Thread: Best solution for this problem
    Senior Member Mat1asBEV&ICE's Avatar
    May 2023
    Boston
    Hello, the chassis harness manual says to drill a 1.25" hole for the main harness to pass through the firewall; last updated 2019. The Coyote Gen 3 fitment says a 1.5" hole; last updated 2023.
    I drilled a 1.25" hole and there was no way the wires would pass through, especially at the Y junction. So I drilled a 1.5" hole, I barely got the wires through. Now I have this problem. What's the best remedy?
    Sorry, not sure why the image is sideways. Thank you!
    Delivery October 2023, #10847, Gen 3, IRS
    The solution is to replace the grommet with one that has a larger O.D.
    May 2023
    Boston
    Thank you, Jeff. Right after I posted I figured "gee, get a new grommet".
    Looks like this one will seal around the cables but it's only rated to 170F. Will that work?
    Thank you.
    Yes.
  5. Thanks Mat1asBEV&ICE thanked for this post
    Oct 2019
    Erin, Ontario CANADA
    Check out https://sealsit.com/product-category/grommet-seal/
    They even offer some split types if needed.
    Earl
  7. Thanks Mat1asBEV&ICE thanked for this post
