Anytime. I'm home for the duration.
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Holley Sniper 2 and Hyperspark, or maybe Edelbrok Pro Flow 4...undecided, TKX, IRS, Wilwood Big Brakes
A couple of updates. Thanks to Greg for pointing out some issues with the front end assembly. I have everything corrected and reassembled (with the exception of the upper ball joints). I also trimmed the UCA arms in the back as suggested in other threads, I hated doing it but a half hour with a dremel and a sander and they cam out fine.
The old ball joints pinched and created tears due to the incorrect installation.
New upper ball joint boots are on Order. Corrected front end assembly??
I have the dash re assembled and everything wired in. After completing this the horns quit working. I naturally went back through the dash assuming I had somehow messed this up.... No change after reassembly.
I finally (after an hour or so) chased this to a bad ground in the Ron Francis harness. The leg for the horn ground was not soldered well to the ground in the front harness. I ended up just grounding the horns directly and removing the leg as it allowed me so insulate the main ground wire better.
Upper control arms look good. These pics are before you shaved the rear adjuster sleeve? Also, I think your pivot arms that connect to your tie rods (or whatever they are called) need to point outward, not inward. Here's mine:
Trunk metal in!!! Thanks Greg for confirming that the manual and current shipped parts vary
How time fly's. I have been lacking in updates for the last couple of months.
Heated Pads placed in seats. These were super simple to do and turned out great. I purchased them from another member here who did not use them.
Clutch Cable Adjusted and working like it should
Brakes bled.
All Dash Wiring is Finished
Both Roll Bars drilled and in Place. I bought the kit used and the drivers roll bar has a gap of about 1/8" where the back leg meets the stub from the hoop. I tried everything (short of grinding and rechroming)but it will have to stay how it is.
I also temporarily mounted the side pipes in preparation for my first go kart drive.
Then the first drive!!!! And it all went wrong from here
What went wrong!!
This is embarrassing but hopefully saves someone else the trouble later. We drove the car maybe 1/4 mile down the street. I pushed the clutch in and immediately knew something was wrong. The car pulled to a halt as if the brakes were on. So we flipped around and went back to the house.
By the time we got to the house the rear brakes were almost locked up and were obviously not working like they should.
After pushing, pulling and using jacks and dollies I got the car back on the lift to dig in.
Rear Brakes were extremely hot (like 200+ Degrees). Pulled the tires and let everything cool down
The Problem!!
I had relied on the previous builder to set the wilwood pedal box up and took it for granted that it was correct because I did not fully understand it myself. I had went over the rest of the car step by step but did not look at the pedal box setup. I should have and was very lucky to not have a bigger issue or tear somethin up.
Upon further inspection and with some quick help from the forum I realized that the master cylinder rods had not been trimmed and that the rear brakes were not releasing.
The rear brake master cylinder was not traveling enough to release the pressure after I hit the brakes at the end of the driveway.
I worked backwards and pulled the rear calipers, pads, e brake setup.
Then pulled the balance bar setup to loosen the pressure on the master cylinder.
I was able to trim the rods to the correct length put everything back together.
I was then able to take both my kids and my wife for a ride. We put about 5 miles on it this weekend with no other issues. I am extremely excited for this step in the build.
