Results 1 to 3 of 3
Thread: Raise front of 302 SBF?
    Kingsland, TX
    FINALLY have the engine/trans installed, but I have an issue, and I've searched the forums looking for a solution, but I don't think anyone else has had this issue. The engine is too low in the front - it's 3-degrees down instead of up, and the trans is as low as it can be. My oil filter (PH11 equivalent) is hitting the power steering housing. Does anyone have any suggestions as to how to raise the front of, and move forward a SBF?
    Attachment 196892 Attachment 196893 Attachment 196894
    Attachment 196889 Attachment 196890 Attachment 196891
    wallace18's Avatar
    Trenton, Florida
    check out post # 86 on my 35 build thread to see what I did.
    https://thefactoryfiveforum.com/show...d-Pickup/page3
    16+ FFR kits and counting!
    Kingsland, TX
    Thanks! This is very helpful!
