35 Truck inventory missing parts
I have completed my inventory today (about two weeks after delivery) Before I send my Missing Parts Form back to Factory Five, I wanted to ask the forum a question.
Am I missing headers?
The exhaust parts listed in box 14 is: Shorty Pipe Parts (the pipes with the O2 bung) and in box 15 are: hangers, mounts, mufflers, exhaust pipes, gaskets, spacers, hardware pack etc. There is no mention of Headers. There is also NO box 16 on my list.
The headers are not listed on the POL sheet.
Anyone have an answer before I add it to my list of missing parts?
Guardm16
I'd assume it depends on what engine you specified... not sure FFR provides headers for all engines? You'll need to check with them. I can say for my build with the Gen 3 Coyote, the kit did include headers.... but I'm not sure if the headers were part of the Coyote eng kit or the '35 Truck kit that came with the headers.
Mark
mkassab
Mark
It's a 351 small block ford (427 stroker) But it makes me wonder: there are several boxes missing from the sequence. All of the boxes listed by Stewart Transport are accounted for however, how would I know if a major box was left out?
Your inventory should reflect the complete list of parts that you ordered. If something wasn't shipped, it will be on your POL list and reflect 0 quantity on your inventory. I suspect that you may not have specified headers on your order, but I don't know if they are included with the truck kit. A call to Factory Five should clear it up.
Papa
When I got my Speedstar kit in August 22 there were more parts outright missing and not on any list than what FFR had identified as back ordered and reflect as such on the POL. So missing parts is a possibility.
To the OP I installed a Hemi in my car and the Hemi install kit did not include headers. The supplemental install instructions listed recommended headers that would mate with the supplied down pipes along with a number of other items that I would need to source.
Dgc333
I know a lot of issues came with FFR's new inventory system, so I don’t doubt that could still be an issue but would expect the bugs have been getting worked out over time. A call to them should help get any issues resolved.
Not a waxer
Headers are included with the Coyote option and manifolds are included with the LS option otherwise they must be purchased separately.
From the order form:
Choose the engine/exhaust system being installed (most require shorty headers):*
33462 - Installing Ford 289/302/351W Engine
34492 - Installing Ford 5.0L Coyote Engine (Includes full length headers)+$899.00
33770 - Installing Chevy LS Series Engine (Includes manifolds)+$975.00
35128 - Installing Chevy Small Block Engine
35113 - Installing Gen 3 Hemi Engine+$150.00
Jeff Kleiner
Thanks Jeff, I went over the order form again today. I found the same section you posted, Not a problem. I just wanted to make sure I wasn't missing something.
It also takes a lot of research to figer out which headers fit.
A problem that I have found with my SBC.
RuffShod
I am going to order a set of ceramic coated from BBK, then go from there.
Does anyone know how long it takes to get a response from FFR on the Missing In Kit "MIK" form. A few of the items are bigger ticket items. The bottom cab bottom floor, the chassis wiring harness and the hood hinges. nuts and bolts here and there are no big deal, but these are kinda impossible (expensive) to replace.
Guardm16
Normally they will respond in just 1-2 business days, but often it's faster than that.
I've had good experiences with items that were MIK for me. My initial MIK list took a couple of days for them to gather together, but once they ship it, they ship it 2 day via FedEx so it gets here quickly. I've had to contact them a couple of times and they've been good each time. Sometimes, you just don't know you're missing something and they're fairly quick to resolve those as well. For example, they didn't send me my motor mounts and they weren't on my shipping list.
I also got a set of ceramic coated BBK headers (BBK-1515) for my 302. Tech support at F5 said they work well for a lot of customers.
Matthew and Noah
'35 Hot Rod Truck - 5.0L 302
Wake Forest, NC
@father.and.son.35
Mr. Jones
I got an email on Tuesday that said, "We are confirming receipt of your MIK list. Please allow our team 1-3 business days to process your order and get back to you with any questions. "
Thanks everyone.
FatherAndSon
You said, "For example, they didn't send me my motor mounts and they weren't on my shipping list." I got the Powder coated chassis mounts, but there were no motor mounts, nor were they on any of the box lists. I checked today, the build manual says, "Unpack the engine and transmission mounts and loosely attach to the engine." That sounds like they are supposed to be in there. I was thinking about solid mounts anyway, Anyone ever done solid mounts on a 500+ HP small block? Just wondering what the vibrations are like.
BBK says part BBK 15110 for the 351, so we will see, they were delivered today
