The Baroness: MkIV Roadster Build Thread
It’s today, it’s today, it’s today.
Best St. Patty’s day surprise ever. Kit gets delivered today between 9AM and 10AM.
First post of the build thread and I’m excited as hell to get started. Let the mayhem begin.
Actually it started a while ago with the motor build.
I’ll be documenting the process on the YouTube as well. You can check out the start of the channel here:
https://www.youtube.com/playlist?lis...ZfA6svVApuwxab
I will try to do my best to take some pics as well.
Some of the details are as follows:
MkIV complete kit
408 LS stroker built by me (you can check out the that build here: https://www.youtube.com/playlist?lis...eYvj5K2kgr4Ct_
TKX transmission from Forte
Wilwood brakes
IRS
Post Thanks / Like - 0 Thanks, 4 Likes
Congrats!!! Looking forward to following your work.
Just watched your LS build. Looking forward to seeing the car build too! Great work on the engine and I am sure the car will be just as well done.
My kit arrived
Super exciting day. Got the call early evening the day before (Mark was my driver). Setup a delivery window and I went off and had a long night of anticipation.
Bunch of friends and family were just as eager, so we setup to have multiple cameras present to capture the moment.
The morning of, I sent my son up the road to be a lookout and my neighbor got a drone up. All of us waiting. I could hardly contain my excitement.
Anyways here's a link to the vid. I had so much footage to scrub through. Have to trim a lot of fat to keep the video around 9 mins.
Mark was awesome. He made it more than just a delivery. He made it an experience to remember.
We talked about the kit. Showed him the motor. Just an awesome time.
He was never in a rush. Just a great guy.
Lots of boxes to go through
Fman liked this post
Congratulations, great day when the FFR trucks rolls up to your house. Your engine looks great! Enjoy the build, awesome journey ahead for you.
Congratulations from a fellow LS builder! I always enjoy seeing the delivery day videos, it brings back the excitement of my delivery day. Mark was also my delivery driver - what a great dude!
Enjoy the build! I dropped my LS3/TKX in the chassis a couple weeks ago for test fitting. A lot of room around the engine.
Roadster delivered 8/27/23
Chevrolet Performance LS3
Loved the video and congrats!!
I got through the inventory of parts in less than a day which was surprising.
Everything for the most part was there which is a testament to FFR packaging. I didn't experience any supply issues left over from the pandemic. Nothing like what I had to wait for when I was building the motor.
Finished up the body buck and got all the aluminum panels off. Exciting stuff.
I'm really leaning towards Cerakoting a lot of the aluminum panels, just not looking forward to the time it's going to take to do it. Overall I think I'll be happier if I do it. But this might open the door to needing to coat a lot more parts as they go in.
I'm really impressed with the Cerakote that I put on the motor as far as durability. Hoisting the motor with chains didn't produce any scratches and nothing seems to stick to it. Not even tape.
I have a feeling that I'm going to be doing a lot of sand blasting for the Cerakote. I'll show my cheap / DIY blasting cabinet which is just a Harbour Freight portable media blaster and a cheap tent.
A couple things to check:
1.) When my kit was delivered FFR had an issue in their system and failed to include the Energy Suspension rear transmission mount. A couple emails and they sent it.
2.) The FFR order system decided a LS/TKX/IRS configuration required driveshaft #16038, which is way too short. The correct driveshaft is #60175. Once again, FFR made right after an email.
Enjoy the build!
BRRT
Enjoy the build!
Ditto on the driveshaft snafu, but not with an LS engine. I am Gen3 Coyote/TKX/IRS, and they got that wrong, too. Did the same thing to another customer around the same time as me with the same engine/trans/rear end config. It's a head scratcher.
Built an early MkIII years ago, sold years ago.
Got Corvettes out of my system, and now back after 18 years to build a MkIV.
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrock Pro Flow 4, TKX, IRS, Wilwood Big Brakes
Here to learn, contribute, and have fun!
BRRT
Enjoy the build!
Good to know. I'll check that out. Thanks for the heads up.
I remember asking them during the order process about the drive shaft specifically cause the order form doesn't really cover it (at least in regards for a LS based power plant).
I checked my notes I took during the conversation when ordering the kit and looks like I requested the #60175 driveshaft as they recommended at the time. I'll check the part itself as well to confirm.
The kit has been fully disassembled and the build has started. She's starting to go together.
Slowly but surely. I think I bit off more than I chew with the Cerakote option. Tons of work, but I think it will be worth it.
Learned somethin about Cerakote "C" series. 1 day after application, I was able to scratch the coating (with effort) to make marks for cutting. After a full 5-7 days of full cure, it's significantly more durable.
I used Cerakote on my engine build and where the hoist chain made contact with the heads, not a mark.
I sand blasted for 2 days before I said that's enough for now. Able to finish all the non-boxed aluminum panels that I want to coat.
Wiped out my air compressor and had to replace after day 1. It served me well over the years with a lot of abuse. Still need to have a semi-portable air compressor or I would have gone with a large 60 gallon compressor or bigger.
I probably won't video much more of the Cerakoting other than some significant stuff, like possibly the side pipes, roll bars (if I don't change my mind), we'll see.
Front suspension components next...
Don't think I would call your tent a redneck solution. Definitely a step above my duct tape, hangers and plastic sheet. Your attention to detail will pay off... going to be a really nice build.
Looking good. I am about a month behind you. My kit gets delivered this Saturday. I am looking into the Cerakote option. Any issues with paint chipping when you drill holes?
twatson799
No chipping so far. I ended up mounting the F-panels about a day after I coated them so they weren't fully cured yet. I was able to scratch them when I scribed to mark it to fit a little better on the top edge.
Once fully cured we'll see.
On the motor, I found the cerakote to be very durable. Nothing stuck to it. It didn't scratch when the hoist chain was rubbing against it, which might be a problem with the silicon on the panels to the rest of the body.
Front suspension goes on.
I checked the fit of the upper control arm ball joints during inventory and ran into the "not wanting to thread all the way in" issue some have ran across.
I ended up ordering Howe racing ball joints and they threaded in no problem. Caught it early so it didn't slow me down any.
I also had to shorted the one side of the upper control arm sleeve and rods to get enough adjustment for the initial alignment. Ended up using an angle grinder and file to clean things up.
Front brakes go on.
Spend some time installing the safety wire and sorting that out.
It's been a really long time since I've had to use safety wire.
Really like the pop of red
Next thing to tackle is the rear brakes
Mentioned in the last post the rear brakes were next. That will be after the rear suspension goes in. Independent Rear Suspension not the Internal Revenue Service
Only issue at the time of recording was I was missing half of the mis-alignment bushings as part of the MIK list.
FFR got them out to me really quick though.
Now the rear brakes can go on...
Can't wait for the next post! I am at the same point in my build. The videos are terrific!
Craig M
I just finished installing the shocks and happened to be lurking on the forum and ran across a thread about the adjustment for the rebound on the shocks.
This got me thinking... are mine setup right? What if one, or some of them are set at different settings?
Well, I dig into it just to make sure and for the peace of mind.
1 out of the 4 was setup at a different setting than the other 3. Drivers side rear was at "1" and all the others were at "0."
I don't think this is really a big deal, unless possibly in the front if one is setup different than the other. Maybe it can induce a bump steer or something else, I'm not sure.
Important thing is now they are all the same and not difficult to check and change if the occasion should present itself.
Found some good directions on the adjustment and went ahead and shot some video which I'll attach below.
KONI Documentation on the adjustment process
https://www.koni-na.com/en-US/NorthA...stment-Guides/
craig6990
Craig M
Thanks for the kind words. Glad they are helpful. Check your shocks if you got the KONI's before you install them. There's a rebound setting. See the info above.
I had to pull my shocks to check them.
Checked mine before the install. I guess that is what comes from scouring the forum for info!!
craig6990
Absolutely... I'm constantly lurking to see if there's anything value added I can say to help someone with a question as well as getting ideas and tips from other builds.
I've built a folder full of reference pics of various little things people have documented in how they addressed something with their build.
I have folders for brake lines, steering, suspension, etc to make it easy to find.
Rear brakes go on. Lots of trial and error with the shims
Next up i think is the pedal assembly
Pedal Assembly goes in, minus the lines
The video's are a little behind from the actual build due to the time it takes to edit as I'm working on installing some of the panels now.
Have a problem I'm going to have to sort out with the throttle pedal. It basically interferes with the side of the firewall at the start of the transmission tunnel.
I think I need to swap the pedal to the other side of the mount... We'll see
Some of the steering components go on.
I opt to use the breeze offset bushings. A little confusion on the install, but I finally sort it out.
Should have read the directions more thoroughly. LOL
It's a tight fit but fits nice.
That is so cool. Thanks for posting.
I start on some of the early aluminum panels.
I'm planning to do the Forte Throttle linkage and noticed the FFR firewall is really flimsy.
I'm not sure if it matters or not, but I modify the firewall to add some thermal protection as well as some rigidity. We'll see how it hold up.
I agree that drilling the holes in the frame is a PIA! I bought the following on AMAZON to make the 1/8" drill bits disposable!
"Lounsweer Cobalt Drill Bits Double End Drill Bits for Hardened Steel Wood Cast Plastic High Speed Metal Stainless Steel Drill Bit(1/8 Inch, 30 Pcs)"
very in expensive for 30 reversable bits!
Just a thought.
Craig M
craig6990
Just a thought.
Craig M
I hear that.
I bought a bunch of 1/8" bits off of amazon as well. Seemed cheaper and quicker in the long run that trying to sharpen the bits with a drill doctor or something similar.
30 pieces for about $20. Not the best bits, but they do the job.
Have to revisit the throttle pedal. Looked like it was going to hit the inboard firewall panel.
Also install a few more panels and perform surgery with an angle grinder with the removal of the FFR parking brake bracket in the tunnel.
Not going to run the manual FFR parking brake. Going to use something different... Eventually
Fuel tank time and Kleiner Mod
Had a little help from my son and a transmission jack to make the install easy
Lines for the "Go Juice" go in.
A little bit of soft line... a little bit of hard line...
Starting to get ready for brake lines so I start with installing the reservoirs.
Some basic fabrication for a bracket and it goes in without any issues.
Moving right along and up to 18 episodes now.
Start of the front brake lines.
A little trial and error and they go in.
Add a line lock, cause why not. We'll say it can act as a parking brake for the front (Yeah that's what it's for). LOL
What next after the front brakes lines?
The rear brake lines of course...
Able to apply my learnings with the fronts so the rear lines went in quicker.
The brakes, for the most part are completely done.
Front and rear reservoirs get plumbed and bled.
Did a modified bench bleed of the master cylinders with them installed on the pedal assembly. Went pretty well.
I would recommend a good flushing of the master cylinders just to make sure any debris is flushed out.
Main wire harness starts going in. Run into a few hiccups along the way on this one.
From plugs not fitting through the firewall to a brake and clutch switch issue. I sort it out though.
Post Thanks / Like - 1 Thanks, 2 Likes
Most of the trunk area panels go in on this episode.
I had to trim a couple of the panels but nothing major.
Enlarged a couple of holes on the upper truck panel to clear some of the welds which were keeping the panel from fully resting flat.
Lot more drilling and a lot more rivets
Drop trunk fabrication
