How do you know if the body is sitting on the frame correctly? I have to adjust the right rear shock up higher to get the same wheel well clearance as the driver side. Seems like either the body is twisted, the frame is twisted or the shock mounts are not the same side to side. So let's start with body, how do you know it's sitting on the frame correctly?
