Hola. I’m knee deep in wiring and I’m having some confusion and uncertainty even after reading build threads. Unfortunately, I’m not one of those people that deals well with uncertainty.
Using Gen 3 Coyote, GPS gauges.
- RF front harness, I can remove the cooling fan wires. Can I also remove that ground cable? Seems like it.
- Regarding the “fuel pump wire from the EFI harness” that I need to connect to the orange fuel pump relay control wire. It’s the very long green wire that connects to the “inline to I/P pigtail”, correct? It doesn't have a label/marking. Just use a red butt connector?
- SMR wire in pigtail connects to “EFI crank” wire?
- The green wire in pigtail labeled “toggle” connects to the orange “coil or EFI” wire?
- Do I need the other three wires (included with the two wires in bullets 3 and 4) in the “coil/EFI crank” bundle for anything?
- RF starter solenoid wires: I am having difficulty seeing how people get rid of all three red wires from coming through the firewall. I know a bus bar is involved. Then I get a little bit lost. I am hoping to mount the PDB on the firewall and mega fuse below it as others have done along with a cutoff switch.
- Any tricks/tips for mounting the mega fuse below the firewall?
Thank you!
