Thanks Thanks:  4
Likes Likes:  2
Results 1 to 13 of 13
Thread: 302 dipstick
    Member Buzzsaw's Avatar
    Jul 2023
    Belmont NC
    302 dipstick
    Is there any trick to installing header on drivers side with dipstick installed? I have tried multiple times to get the header over the dip stick tube bracket (dip stick removed) but no success. Do you have to remove the dipstick assembly to install the header? If the dipstick assembly is removed can it be reinstalled and not leak? Dipstick assembly = dipstick tube and welded bracket and dipstick
    Thanks!
    Ross
    MK4 kit delivered 11-5-2023 Forte’s Ford 302, Edelbrock Pro Flow 4 fuel injection, Tremec TKX transmission mid shift option, 355 ratio rear end, 17”wheels, 2015 Mustang IRS from FFR
    The dipstick tube pulls out of the block, no o rings. If you have difficulty inserting after header assembly you may need to change from the Ford dipstick to an aftermarket one. I ended up with a Lokar dipstick assembly that comes up between the header pipes. Expensive but it works. There are other makes out there that I believe are lower cost.
    Jul 2023
    Belmont NC
    Quote Originally Posted by PG_Cobra View Post
    Thanks PG-Cobra! If there is no O ring or membrane, just a metal to metal fit prevents an oil leak?
    Thanks Ross
    Oct 2019
    Erin, Ontario CANADA
    Also if you do end up installing a new different dipstick, take the time to "calibrate" its length against that of the old one.
    Earl
  5. Thanks Buzzsaw thanked for this post
    Quote Originally Posted by Buzzsaw View Post
    Thanks Ross
    Yes, metal to metal with the Ford part. It doesn't leak (much). The Lokar part I installed has an O ring and fully seals. All that being said I have an under car exhaust with hugger headers from Speedway heading down between the frame and the engine. Space is tight but the Kovar part still fit.
  7. Thanks Buzzsaw thanked for this post
  8. #6
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Thanks Ross
    Just put a bead of RTV on the tube, should seal up nicely.
    Matt
    My build thread here
  9. Thanks Buzzsaw thanked for this post
    Likes J R Jones liked this post
  10. #7
    Jul 2023
    Belmont NC
    Quote Originally Posted by narly1 View Post
    Earl
    Thanks Earl, you’re right there are so many dipsticks out there. It would be bad to find out you run a few thousand miles a quart low!
  11. #8
    Jul 2023
    Belmont NC
    I looked at a 302 crate engine only dip stick assembly this morning and it was metal to metal. I will try to make the factory stick work and look at Lokar as a secondary option. Thanks for your help PG!
  12. #9
    Jul 2023
    Belmont NC
    Quote Originally Posted by MB750 View Post
    Thanks Matt.
  13. Likes MB750 liked this post
  14. #10
    Feb 2022
    Tampa, FL
    Thanks Matt.
    One of the tricks I do with RTV is spray both surfaces down with carb cleaner or acetone before applying the RTV. It pretty much guarantees a good seal.
    I know you shouldn't spray carb cleaner into the dip stick hole, so maybe use a Q-tip or something like that to clean the surface.
    Matt
  15. Thanks Buzzsaw thanked for this post
  16. #11
    Jul 2023
    Belmont NC
    Thanks Matt!!!
  17. #12
    May 2022
    Fishers, Indiana
    I have a Blue Print 302 the dip stick has 2 different diameters before the stop ring. The second diameter from the end will not fit into the block. I was assuming the dipstick should go all the way to the large ring. Are you seeing the same issue?
  18. #13
    Jul 2023
    Belmont NC
    Quote Originally Posted by Malibu46pt View Post
    Hi Malibu, I have a Ford Boss 302 block so it may be different from the block blue print uses. I only have one diameter size before one stop ring. My dipstick goes into the stop ring but fits loosely.
