Papa
As many of you know, I'm moving to Missouri in a couple of weeks. I now have the opportunity to design and build another shop. Here is an initial design idea I've drafted up:
As drawn, the building is 50' wide x 30' deep with an additional 20' x 12' workshop and bathroom area. The center door on the front is 16' x 10' and the three smaller doors are 10' x 9'. The ceiling is 12' to accommodate a lift and the left bay is a drive-through for my tractor.
What would you all do differently? The size is constrained by the building envelope that I have, so I can't go bigger than the 1,740 square feet that I have with maybe some minor tweaks possible (a foot here or there).
Lots of good thoughts here - I'll echo the radiant heat suggestion especially with high ceilings. It is way more comfortable to work when floor is actually radiating heat to you instead of sucking the heat out of you. Can actually keep the air temperature lower and still be comfortable. I also used a small tankless hot water heater and has been going strong for 10+ years.
I am curious what software you used to design the above?
Todd
smithtlw
Todd
The software I'm using for the design is DreamPlan Home Design, which has a free trial version you can order and download from Amazon. It's very basic, but enough to get some decent visuals. The non-trial version is $40.
https://www.amazon.com/gp/product/B0...1?ie=UTF8&th=1
I use my computer in the garage all the time I haven't installed the smart TV on a swivel mount yet. (if no one mentioned it already..) You'll need more seating for all the visitors you'll have to marvel at the garage!!
2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23.
Papa liked this post
I'm sure you've taken this into consideration, but try to place your doors to get the best possible cross breeze and take that afternoon sun into account....I'm from Texas so my priorities are different. LOL. It gets plenty hot and humid in Missouri! One of the hottest days of my life was at an outdoor wedding in Joplin Mo. in August.
Papa thanked for this post
3rd or 4th the radiant floor heating as well as mini-splits for AC/heat.
Maybe a good size I-beam so you can hang a winch on it for pulling engines or anything heavy.
I had 2 in my last house, they were very handy.
Heated floor, a blessing while building my Daytona.
Electrical outlet on the ceiling, useful…once in a while.
I don’t know but after getting a heated floor one must be careful not drilling into heating mesh or tubular if liquid heated.Just asking…
Francois
Transom windows over garage door add some natural light when the doors are closed and I am all for radiant heat, I have 2 "garages" with radiant and there is nothing better in may opinion and for $75/month for 1400sq feet with 18 ft high celings in MA at 60 degrees I don't complain
Update: Trying to find a builder that could do the shop this year at a price that made sense put me on a completely different path. Here is what we ended up going with!
The building will go up this summer (August timeframe).
I like it! Tall ceilings and a covered porch to put your BBQ
JimStone
Yep! I did 14' ceilings with high-lift garage door tracks and header-mount openers. The doors will line up with my existing driveway for a nice straight-in entry. The concrete will be 5" thick to easily accommodate a lift. I still need to work out the electrical details, but plan to go with surface mount wiring in conduit. The walls will be finished from the floor to a height of 8' in OSB and then metal the last six feet. The ceiling will be metal and the entire building will be fully insulated, including the doors.
Might want to have piers poured where the lift pads will sit. When I built my garage, I specified the lift and the weight and the concrete engineer drew in 4' piers under the pads with 3/4" cross-tied rebar. My soil also has a lot of clay in it, and that was a factor as well. 11 years later and not a single hair line crack anywhere on the slab.
Just a thought.
