Results 1 to 3 of 3
Thread: Coilovers hitting bracket
    NY
    Using 4 link setup, I have the upper spacers in like the manual says, but even pulling a spacer out its still a close fit, any ideas ?
    Port Charlotte, FL
    Can you flip the coil overs over?
    Henry
    Remove the bracket? Looks like it is for the brake line. So move it, bend it, twist it, cut it to bolt to the upright welded to the top of the axle housing? Also looking at the coil over in side view there is virtually no angle change during suspension movement. So you can space it out (rearward) from the axle by juggling the spacers on the bolt or replacing some of them w/ washers.
