Thanks Thanks:  4
Likes Likes:  3
Results 1 to 8 of 8
Thread: TH 350 in hot rod
    Senior Member Ltfracing's Avatar
    Aug 2022
    TH 350 in hot rod
    Has anyone put a TH 350 in a 33 hot rod,any modifications that need to be done to the crossmember ,thank you
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
    Apr 2023
    Yes, going old school, I like that! Installed mine a few years back. Nothing to special. Mounted the crossmember upside down and used 1/2" spacers to get the angle I was looking for to mate to the IRS.
  3. Thanks Ltfracing thanked for this post
    Likes Ltfracing liked this post
    Aug 2022
    Do you have any pictures of how you installed it sir
    Apr 2023
  6. Thanks Ltfracing thanked for this post
  7. #5
    Aug 2022
    Did you have to do anything to your driveshaft sir
  8. #6
    Apr 2023
    No, I was able to use the one FF supplied with the kit when I told them I was installing a SBC383 w/ a TH350. I installed a Holley Sniper EFI with their Hyperspark distributor which is smaller than most so I was able to slide the engine and tranny back a little more to help with the engagement with the driveshaft.
  9. Thanks Ltfracing thanked for this post
  10. #7
    Aug 2022
    Thank you sir,do you remember the parts # of the driveshaft they sent you any chance you could give me a measurement of it,thank you sir
  11. #8
    Apr 2023
    FF part # 34048 which I believe is 31" long. My transmission tail shaft is 6" long and I believe 27 spline. If I remember right, I also bought a longer slip yoke from Denny's Driveshafts so to have better engagement into the tranny. I didn't figure that out until I had the tranny and IRS mounted that I realized the slip yoke would be to short. I read somewhere that you want it to engage 1" shy of bottoming out inside of the tail housing.
    Hope this helps.
  12. Thanks Ltfracing thanked for this post
