Results 1 to 6 of 6
Thread: 03-04 Cobra - same as S197
    Apr 2024
    I found a rear end I would like to use in my Hot rod Truck kit, it's for 03-04 Cobra - anyone know of that will work?
    Appreciate any help or info, thanks
    Maricopa AZ
    Not the same.
    Apr 2024
    Quote Originally Posted by scspeedster View Post
    Maricopa AZ
    The S197 diff is wider and has a single upper link bushing.
  5. Thanks scspeedster thanked for this post
    Senior Member Its Bruce's Avatar
    Houston TX
    I can assure you that rear end did not come from an 03/04 Cobra. It may fit one, but it would.replace the OE IRS.
    Prescott, AZ
    I used a 2004 Mach 1 as a donor for my MK4 in 2011. The Mach 1 used a live axle as shown. I had to narrow mine so that I could use 315s out back. It is a good rear axle to use if you are going 3-link and willing to narrow it. It also has the ABS tone rings if ABS is of interest to you.
    The Cobra has a IRS rear suspension as I recall, so that is not from the Cobra but more likely from the Mach 1 or possibly from the GT.
