Likes Likes:  2
Results 1 to 16 of 16
Thread: Wiring Vintage Gauges
    Senior Member Jonathan D's Avatar
    Jun 2012
    New Brunswick, Canada
    I'm starting to wire my gauges and I have looking on the site to see what others have done but I'm not finding anything out there with this version that plugs directly into the back of the gauge. I'm thinking these will be easy to unplug and service without needing extra plugs between them and the RF harness but I would love to see a few other posts on wiring these if anyone can share. Also curious if guys are using these sending unit wires that come with the gauges...I believe the RF kit has the wiring already, minus the actual sending unit. Wiring is certaintly my not my strong suit.
    MK4 Build In Progress - Carb 331 Stroker, T5, 355, 15's, Pwr Brakes & Steering
    Build Page https://thefactoryfiveforum.com/show...Canadian-Build
    Just from the page you are displaying in your picture, it looks like you are in the wrong part of the wiring manual. The vintage gauges come further into the manual and don't have you building the multi-wire daisy chain that the Autometer gauges do. If I recall, the gauges changed after my version, but for mine, you had to remove the plugs and wire the senders to the gauges. The lights and power were all simple plug-ins. Look for the section in the Chassis Wiring manual labeled: GPS Vintage gauge install.
  3. Thanks Jonathan D thanked for this post
    Senior Member Mat1asBEV&ICE's Avatar
    May 2023
    Boston
    I did some research on this subject recently. People got in touch with Speedhut and they said to use their wires for the sending units. Seems much better than splicing at the sending unit and then again at the gauge.
    Delivery October 2023, #10847, Gen 3, IRS
  5. Likes Jonathan D liked this post
  6. #4
    This subject is asked about a lot and there's no right answer IMO. Whatever works best for you and that you understand and can implement. Some guys home run the Speedhut wires directly to the gauges. I guess I understand why Speedhut would recommend this because it reduces some variability in the installation. But electrically there's no difference if you use the Ron Francis sending unit wires. That's the camp I'm in on multiple builds. i splice the ends of the Speedhut wires into the RF dash harness and connect the gauges. Then use the RF sending unit wires out to the appropriate location. For me the advantage is now the dash has just the two large RF block connectors. In 10+ years, I've only had to take a dash out once (my Coupe) and was happy I did it that way.
  7. Likes Jonathan D liked this post
  8. #5
    May 2023
    Boston
    I will add to carefully compare the wiring between the RF harness and the sending wires that come with the gauges. For both of my RF signal wire connectors where they would hook up to the back of the gauges, water temp and oil pressure, the signal wires were not in the same slot (there are three) as those supplied by Speedhut.
  9. #6
    Aug 2022
    Portland, Oregon
    I did the "homerun" from sender to gauge using the speed hut wires for the engine sending units (oil press, oil temp, water temp). If you start early in the process, pretty easy to bust those out of the RF harness. I bought some connectors and re-used the empty terminals in the RF harness connectors to provide some power feeds to my zero dimmer and ensure there was lots of grounds.
    I found some connector concerns on the RF harness that the wire did not match where the speed hut wire connected, and read some post that the had the incorrect wiring there for others. You can not beat the quality of the speed hut wiring, I started to do the splice trick into the RF connector, cut 1 wire apart and realized the shielding and ground of the Speed hut wire was high quality and due to the engine sending units running close proximity to the tach signal and coil power, I thought the shielding would ensure a good signal.
    The Fuel sending unit is the only item I spliced into the RF harness connector. Truth be told if I had the gauge package out when I ran my rear harness, I would have done the fuel sender as well.
  10. #7
    Jul 2021
    Tonganoxie, KS
    Just did my dash wiring this weekend with my Speedhut custom gauges. I'm going to homerun all the sender wiring; it appears to be better quality than the RF equivalent. Only exception is the fuel level sender wiring. I need to re-do the three gauges that I've hooked into the RF wiring for the senders. That's this weekend's task.
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrock Pro Flow 4, TKX, IRS, Wilwood Big Brakes
  11. #8
    Nice clean work!
  12. #9
    Jul 2021
    Tonganoxie, KS
    Nice clean work!
    Thanks! The thing I was least proud of on my MkIII was wiring...it was kind of a mess. I've been inspired by many build threads to do better...it's not to the level of, say Papa or EdwardB (), but it's miles better than my first build!
    Greg
  13. #10
    Jun 2012
    Quote Originally Posted by Mat1asBEV&ICE View Post
    Great tip, I just looked at mine and they are also pined in different spots and the oil sender from speedhut is 3 wire but the RF is 2 wire.
  14. #11
    Jun 2012
    Quote Originally Posted by F500guy View Post
    Thanks, the more I look at these senders from speedhut and the fact that many of the gauge plugs are wired differently than the RF I'm going to homerun them as well.
  15. #12
    Greg
    Don't cut yourself short. That wiring is way cleaner than mine!
  16. #13
    Jun 2012
    Thanks for sharing, this is looking really nice!! I just purchased wago connectors last night to do the same kind of thing you have done here. Are you just leaving one connection in those connectors open to add your power or ground wires into?
  17. #14
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by Jonathan D View Post
    Correct. These power distribution gizmos came with my Speedhut gauges. The top 'port' on each is where power and ground come in. BTW...I secured them to the back of the dash with 3M emblem tape. Solid.
  18. #15
    Jun 2012
    Mine didnt come with any of those and I like how yours came color matched! Maybe thats an update that came after my kit. Thanks for confirming how you are running yours and I would love to see how yours looks when finished. Great tip on the 3m tape too.
  19. #16
    Jul 2021
    Tonganoxie, KS
    I ordered my gauges directly from Speedhut as a package. My complete kit came with the no-charge Platinum gauges, which I knew I wasn't going to use. Maybe that's the difference. I'm sure Speedhut would sell you those doohickies if you called them.
