Thread: Fuel sending unit question
    Jun 2022
    Chantilly, VA
    Like to get some advice…. Wish I had more experience here.
    Going to run a 383 stroker with a Holley Sniper EFI. Spoke to Holley and their recommendation is to run all 3/8” fuel lines (supply and return). I did. Now looking at return on the sending unit and it is a 1/4 inch pipe on the sending unit. Seemed to be a “restriction”. Holley recommended to change it to 3/8” pipe and suggested the return tube should go down to about 1” from the bottom of the sending unit towards the bottom of the tank. The 1/4 inch return pipe in the sending unit extends about 3/4 inch below the top of the sending unit so it would have to be extended 6 plus inches.
    So, here are my questions…
    1- Is this a concern and has anyone run into problems with the 1/4 inch return on the sending unit for a 383 / sniper EFI configuration when rest is 3/8” fuel lines?
    2- Anyone do anything to increase volume on the return pipe of the sending unit and if so what did you do? E.G. drill out 1/4 tube and weld in 3/8”?
    3- Do you need to extend the return deeper into the tank regardless the configuration and if so what did you all do?
    Hopefully I am just thinking about it too much ;-)
    Thanks in advance all.
    I have the exact configuration 383/Sniper but I went 3/8 all the way, I used a Boyd Aftermarket tank. The advice about the return location low in the tank is spot on, that will avoid cavitation. JMHO
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    I replaced the Roadster kit-supplied fuel pump hanger with the Pro-M 87-93 Mustang Race hanger. It has 3/8" feed and 3/8" return fittings, both -6AN. It also has a return extension, to ensure return fuel doesn't cause cavitation.
    High Flow Fuel Pump Hanger for 1986 – 1997 Mustangs (promracing.com)
    Built an early MkIII years ago, sold years ago.
    Got Corvettes out of my system, and now back after 18 years to build a MkIV.
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrock Pro Flow 4, TKX, IRS, Wilwood Big Brakes
    Here to learn, contribute, and have fun!
    Jun 2022
    Chantilly, VA
    Appreciate the info…thanks!
    Jun 2022
    Chantilly, VA
    Great videos with the link! Thanks for the info!
    Jul 2021
    Tonganoxie, KS
    You bet. Happy to help.
    Senior Member MPTech's Avatar
    St. Louis, MO
    x2 Greg's suggestion on the Pro-M Hanger. All your problems resolved and keep your existing fuel tank.
    I'm running a fresh 347 build with Sniper EFI all 3/8".
    Jun 2022
    Chantilly, VA
    Thanks!
