Thread: Hydraulic clutch slave bracket help
    Dec 2023
    So I got the wrong bracket for the slave cylinder. Didn't notice until it was time to install the engine. Forte sent me the correct one now. I assumed it would mount to the out side of the transmission case. Apparently not for a T5. Engine is already installed so I am trying to think about how to mount that bracket with out removing the engine or transmission.
    Suggestions on mounting?
    Maybe I can drill the bell housing from the outside?
    Mk IV, IRS, 302 w/EFI & T5, 15" wheels
    Dec 2023
    Found this on line. Not sure if anybody has tried this solution.
    https://www.rosehillperformanceparts.com/sale/T5.html
    Pittsburgh, PA
    I fabricated something similar to the bracket linked in the second post. It works really well.
    Feb 2020
    Chicago
    You shouldn't have to remove the engine. remove the Transmission Y mount with a jack under the trans. you should be able to lower the trans via the jack and mount the new bracket.
    Dec 2023
    Jiriza, that is way more work than I really want to do. Just ordered the bracket from post #2.
    Dec 2023
    The external bracket worked well and would recommend it. I just added a spacer on the bolt to make the head a bit easier to get to with a wrench for tightening.
